Me
FlashBuilder 4.7 Premium
Flex SDK 4.6.0 w/ Air 3.5 overlayed
Mac OS X 10.8.2
I'm trying to run a small app from one of the FeathersUI tutorials. It runs fine on the Air Simulator, but once I try to run it on the iOS Simulator I get:
Error occurred while packaging the application:
Exception in thread "main" java.lang.Error: Unable to find llvm JNI lib in:
/Applications/Adobe Flash Builder 4.7/eclipse/plugins/com.adobe.flash.compiler_4.7.0.349722/AIRSDK/lib/adt.jar/Darwin
/Applications/Adobe Flash Builder 4.7/eclipse/plugins/com.adobe.flash.compiler_4.7.0.349722/AIRSDK/lib/aot/lib/x64
at adobe.abc.LLVMEmitter.loadJNI(LLVMEmitter.java:582)
at adobe.abc.LLVMEmitter.<clinit>(LLVMEmitter.java:596)
at com.adobe.air.ipa.AOTCompiler.generateExtensionsGlue(AOTCompiler.java:419)
at com.adobe.air.ipa.AOTCompiler.generateMachineBinaries(AOTCompiler.java:1790)
at com.adobe.air.ipa.IPAOutputStream.createIosBinary(IPAOutputStream.java:378)
at com.adobe.air.ipa.IPAOutputStream.finalizeSig(IPAOutputStream.java:743)
at com.adobe.air.ApplicationPackager.createPackage(ApplicationPackager.java:91)
at com.adobe.air.ipa.IPAPackager.createPackage(IPAPackager.java:245)
at com.adobe.air.ADT.parseArgsAndGo(ADT.java:571)
at com.adobe.air.ADT.run(ADT.java:419)
at com.adobe.air.ADT.main(ADT.java:469)
I've read several different forums on Adobe and I see suggestions to remove Java 7 in favor of Java 6 (this isn't really a solution). I see to overlay Air SDK 3.4+ because Flex SDK 4.6 that comes with FB 4.7 is using Air 3.1. This didn't work.
I would really like to know the solution for this problem as well i am using a mac and i have the same problem with FB and Flash professional CS6
I had to overlay the 3.5 Air SDK over 2 locations in the FB 4.7 app.
I hope this helps you.
