Could someone explain to me "specifically" what do "you" do
to remove the IE6 message "Press spacebar to activate or use
control" message from a coldFusion "Cfform" or "CFgrid"? I've been
successfull at removing the message from a Flash movie in my
Javascript. But how do you do that with a whole Coldfusion form.
With the stand-alone Flash movie in my Javascript we write
the "string" that produces the Flash object to a varible, then call
a external Javascript file to "document.write" the object out
again, but how would you do that with a Flash Coldfusion form or a
CFGrid? The Flash Coldfusion form's code is generated dynamically?
Could someone explain specifically what I need to do to
correct this problem?
