15 Replies Latest reply on Dec 20, 2012 12:47 PM by gator soup
    New CS6 is crashing and now my old CS2 is crashing too.
    heyhon Level 1
      I posted this before, was told it was probably a font conflict, paid $70 for Font Doctor, ran that, cleaned up the fonts and its still crashing by simply scrolling thru to find a file to open and to make matters worse, my CS2 which hardly ever crashed now crashes just opening it. I am rather beside myself, I have an iMac running 10.6.8 with 4GB of memory. I would love to copy and paste the crash report but it's not letting me do that - is there a specific line in that report that I could type out that would tell anyone anything?? HELP!
        • 1. Re: New CS6 is crashing and now my old CS2 is crashing too.
          Curt Y Level 7
          Font managers help but are not foolproof.  If it best to make your fonts unavailable to PS.  If it works then add in 1/2 of them.  If that works add in half of the remaining.  Continue this until you find the batch that causes the problem.   Then start adding them in one at a time until you find the culprit.
          • 2. Re: New CS6 is crashing and now my old CS2 is crashing too.
            Mylenium Most Valuable Participant
            Crash reports can be provided via Pastebin or otehr sites. You can find them in your Application Support:Logs or Library:Logs or the System folder as XML/ text files.
            Mylenium
            • 3. Re: New CS6 is crashing and now my old CS2 is crashing too.
              Michiharu Ariza Adobe Employee
              How to find a crash log:
              Run "Console" application. This is located under folder Applications/Utilities.
              In its window, application crash logs are listed under the group "User Diagnostic Reports". Click on the triangle to reveal logs if it is pointing to the right.
              Click on the last Photoshop CS6 crash log to show its contents to the right.
              You should be able to copy the log contents at this point, but if for some reason it doesn't let you, look for a line that reads "Crashed Thread: (number)". The number is often 0, but may be different.
              Then look for a line that reads "Thread (number) Crashed:" corresponding to that number.
              Following lines prefixed with a number starting with zero indicate where the application crashed. This is the most informative part of the crash log. Type out a few lines in this forum.
              If you get Adobe (not Apple one) crash reporter dialog soon after a crash, clicking on "Crash Data" on the lower left also reveals the crash log. Sending a response with your e-mail address helps us diagnose the problem too.
              • 4. Re: New CS6 is crashing and now my old CS2 is crashing too.
                heyhon Level 1
                still not letting me copy and paste out of the console but here is that line:
                crashed thread: 0   Dispatch queue: com.apple.main-thread
                application specific information:
                ***error for object 0x107b08408: incorrect checksum for freed object - object was probably modified after being freed
                Photoshop crashed just by opening it and scrolling to open a file, this is typical.
                • 5. Re: New CS6 is crashing and now my old CS2 is crashing too.
                  Do you see names like CoreText, HIToolBox, or ATS soon after that line, like the one discussed here?
                  http://forums.adobe.com/message/4921680#4921680
                  In that case, crashing within the OS code. I have no idea what's causing it.
                  Reducing the number of active fonts may help if it is caused by a particular font.
                  If you have 800 fonts, cut in half to 400, and so on.
                  • 6. Re: New CS6 is crashing and now my old CS2 is crashing too.
                    heyhon Level 1
                    I don't see any of those in the crash log. Since it crashes just by scrolling to find a file, I was able to use Bridge yesterday to find the file and open it that way and it actually let me work on something basic without crashing - any thoughts on that?
                    • 7. Re: New CS6 is crashing and now my old CS2 is crashing too.
                      gator soup Level 4
                      three standard tips
                      1) Run Disk Utility> Repair Disk and Repair Permissions
                      2) Run a utility like Cocktail OSX (especially Caches> User all)
                      then reboot, still no joy
                      3) try creating an admin New User Account (System Preferences> Accounts) and test (this rules out preferences and user settings by restoring defaults in the new account)
                      after that you are probably looking at a bad system install, but you may also want to at least double your ram for CS6...
                      • 8. Re: New CS6 is crashing and now my old CS2 is crashing too.
                        No idea, but since you can't copy from console window, which is unusual, something must be wrong in your system.
                        Can you copy and paste or browse files in OS app like TextEdit?
                        Maybe a time to upgrade your OS. We know Apple fixed many issues since 10.6.8.
                        • 9. Re: New CS6 is crashing and now my old CS2 is crashing too.
                          heyhon Level 1
                          I can copy and paste files into TextEdit but it's this window where I can't paste anything.
                          Any idea why Photoshop CS2 which never crashes all of the sudden crashes on startup everytime now that Photoshop CS6 is installed - could the software be wonky??
                          • 10. Re: New CS6 is crashing and now my old CS2 is crashing too.
                            heyhon Level 1
                            Ran Disk Repair, bought and Ran Cocktail - no joy.
                            Restarted as a different user and CS6 seemed to be fine, it let me scroll without crashing, CS2 crashed immediately.
                            What do you mean by a bad system install?
                            • 11. Re: New CS6 is crashing and now my old CS2 is crashing too.
                              Level 7
                              It sounds like you've got a system level problem (bug in the OS).
                              Corrupt fonts and corrupt OS font caches have been known to do that.
                              But we really need to see the full crash log to figure out what is going on.
                              • 12. Re: New CS6 is crashing and now my old CS2 is crashing too.
                                heyhon Level 1
                                Here is the CS2 crash report (switched from Firefox to Safari, now I can copy and paste)
                                Process:         Adobe Photoshop CS2 [206]
                                Path:            /Applications/older software/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2
                                Identifier:      com.adobe.Photoshop
                                Version:         9.0 (9.0x196) (9.0)
                                Code Type:       PPC (Translated)
                                Parent Process:  launchd [109]
                                Date/Time:       2012-12-20 12:44:26.240 -0500
                                OS Version:      Mac OS X 10.6.8 (10K549)
                                Report Version:  6
                                Exception Type:  EXC_CRASH (SIGILL)
                                Exception Codes: 0x0000000000000000, 0x0000000000000000
                                Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
                                0   libSystem.B.dylib                       0x80239236 __pthread_kill + 10
                                1   libSystem.B.dylib                       0x80238ad7 pthread_kill + 95
                                2   com.adobe.Photoshop                     0xb80f5a71 gettimeofday_wrapper + 37593
                                3   ???                                     0x1c1bab8f 0 + 471575439
                                Thread 1:
                                0   libSystem.B.dylib                       0x80142afa mach_msg_trap + 10
                                1   libSystem.B.dylib                       0x80143267 mach_msg + 68
                                2   com.adobe.Photoshop                     0xb819440f CallPPCFunctionAtAddressInt + 206231
                                3   libSystem.B.dylib                       0x80170259 _pthread_start + 345
                                4   libSystem.B.dylib                       0x801700de thread_start + 34
                                Thread 2:
                                0   com.adobe.Photoshop                     0xb815acc0 spin_lock_wrapper + 90152
                                1   com.adobe.Photoshop                     0xb8179c5b CallPPCFunctionAtAddressInt + 97763
                                2   com.adobe.Photoshop                     0xb80c6b13 0xb8000000 + 813843
                                3   com.adobe.Photoshop                     0xb80c0037 0xb8000000 + 786487
                                4   com.adobe.Photoshop                     0xb80dd8e8 0xb8000000 + 907496
                                5   com.adobe.Photoshop                     0xb8145397 spin_lock_wrapper + 1791
                                6   com.adobe.Photoshop                     0xb801ceb7 0xb8000000 + 118455
                                Thread 3:
                                0   com.adobe.Photoshop                     0xb815a8ff spin_lock_wrapper + 89191
                                1   com.adobe.Photoshop                     0xb8176e5d CallPPCFunctionAtAddressInt + 85989
                                Thread 4:
                                Thread 0 crashed with X86 Thread State (32-bit):
                                  eax: 0x00000000  ebx: 0x802fc540  ecx: 0xb7fffa6c  edx: 0x80239236
                                  edi: 0xb81f8714  esi: 0x00000004  ebp: 0xb7fffa98  esp: 0xb7fffa6c
                                   ss: 0x0000001f  efl: 0x00000286  eip: 0x80239236   cs: 0x00000007
                                   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
                                  cr2: 0x8023922c
                                Binary Images:
                                0x80000000 - 0x8005dff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                0x8007d000 - 0x800e7fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
                                0x80142000 - 0x802e9ff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
                                0x8036b000 - 0x804e6fe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                0x805de000 - 0x805ecfe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
                                0x805f1000 - 0x805fdff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
                                0x80601000 - 0x80647ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
                                0x80654000 - 0x807d6fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <50A70082-F800-93D8-1A7C-C95AAB1F352C> /usr/lib/libicucore.A.dylib
                                0x80838000 - 0x808e5fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
                                0x808f9000 - 0x808fcfe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
                                0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
                                0xb8000000 - 0xb81defff +com.adobe.Photoshop 9.0 (9.0x196) (9.0) <F24FBFDD-E694-6F38-BFFB-293613CEF2DE> /Applications/older software/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2
                                0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
                                Translated Code Information:
                                objc[206]: garbage collection is ON
                                NO CRASH REPORT
                                • 13. Re: New CS6 is crashing and now my old CS2 is crashing too.
                                  heyhon Level 1
                                  and here is the CS6 crash report
                                  Process:         Adobe Photoshop CS6 [2341]
                                  Path:            /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                                  Version:         13.0.0 (20120315.r.428)
                                  Code Type:       X86-64 (Native)
                                  Parent Process:  launchd [99]
                                  Date/Time:       2012-12-20 10:53:10.721 -0500
                                  Report Version:  6
                                  Exception Type:  EXC_CRASH (SIGABRT)
                                  Application Specific Information:
                                  *** error for object 0x107b08408: incorrect checksum for freed object - object was probably modified after being freed.
                                  0   libSystem.B.dylib                       0x00007fff891130b6 __kill + 10
                                  1   libSystem.B.dylib                       0x00007fff891b39f6 abort + 83
                                  2   libSystem.B.dylib                       0x00007fff891a262d szone_error + 519
                                  3   libSystem.B.dylib                       0x00007fff890cc854 small_malloc_from_free_list + 473
                                  4   libSystem.B.dylib                       0x00007fff890c91e1 szone_malloc_should_clear + 2070
                                  5   libSystem.B.dylib                       0x00007fff890c898a malloc_zone_malloc + 82
                                  6   com.apple.CoreFoundation                0x00007fff815266a0 __CFBasicHashRehash + 240
                                  7   com.apple.CoreFoundation                0x00007fff81547f07 CFBasicHashRemoveValue + 1143
                                  8   com.apple.CoreFoundation                0x00007fff81572fac CFRunLoopRemoveSource + 700
                                  9   com.apple.CoreFoundation                0x00007fff8155a5a2 __CFSetApplyFunction_block_invoke_1 + 18
                                  10  com.apple.CoreFoundation                0x00007fff8154ead5 CFBasicHashApply + 213
                                  11  com.apple.CoreFoundation                0x00007fff8155a55f CFSetApplyFunction + 191
                                  12  com.apple.CoreFoundation                0x00007fff81572f21 CFRunLoopRemoveSource + 561
                                  13  com.apple.DesktopServices               0x00007fff855b30cf TClientChangeNotifier::~TClientChangeNotifier() + 81
                                  14  com.apple.DesktopServices               0x00007fff855b31d0 TClientChangeNotifier::RemovePtrReference() + 108
                                  15  com.apple.DesktopServices               0x00007fff855b3068 TNotifier::RemovePtrReference() + 40
                                  16  com.apple.DesktopServices               0x00007fff855bad67 TNodeRequest::~TNodeRequest() + 33
                                  17  com.apple.DesktopServices               0x00007fff855bad31 TNodeRequest::RemovePtrReference() + 35
                                  18  com.apple.DesktopServices               0x00007fff855c0dae NodeDisposeRequest + 48
                                  19  com.apple.AppKit                        0x00007fff82a6581e -[NSNavFBENode copyIcon] + 105
                                  20  com.apple.AppKit                        0x00007fff82a56a23 -[NSNavBrowserCell drawInteriorWithFrame:inView:] + 923
                                  21  com.apple.AppKit                        0x00007fff827118d9 -[NSOutlineView _drawContentsAtRow:column:withCellFrame:] + 95
                                  22  com.apple.AppKit                        0x00007fff827109fc -[NSTableView drawRow:clipRect:] + 1242
                                  23  com.apple.AppKit                        0x00007fff82a7406f -[NSNavOutlineView drawRow:clipRect:] + 321
                                  24  com.apple.AppKit                        0x00007fff827102ef -[NSTableView drawRowIndexes:clipRect:] + 369
                                  25  com.apple.AppKit                        0x00007fff82710170 -[NSOutlineView drawRowIndexes:clipRect:] + 131
                                  26  com.apple.AppKit                        0x00007fff8270ec9c -[NSTableView drawRect:] + 1302
                                  27  com.apple.AppKit                        0x00007fff82704d75 -[NSView _drawRect:clip:] + 3566
                                  28  com.apple.AppKit                        0x00007fff8270254b -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 2112
                                  29  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  30  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  31  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  32  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  33  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  34  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  35  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  36  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  37  com.apple.AppKit                        0x00007fff82702ed6 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
                                  38  com.apple.AppKit                        0x00007fff82701b2c -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 254
                                  39  com.apple.AppKit                        0x00007fff826fe3de -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2683
                                  40  com.apple.AppKit                        0x00007fff82677c0e -[NSView displayIfNeeded] + 969
                                  41  com.apple.AppKit                        0x00007fff82672aba _handleWindowNeedsDisplay + 678
                                  42  com.apple.CoreFoundation                0x00007fff81593b07 __CFRunLoopDoObservers + 519
                                  43  com.apple.CoreFoundation                0x00007fff8156f434 __CFRunLoopRun + 468
                                  44  com.apple.CoreFoundation                0x00007fff8156ed8f CFRunLoopRunSpecific + 575
                                  45  com.apple.HIToolbox                     0x00007fff89f4d7ee RunCurrentEventLoopInMode + 333
                                  46  com.apple.HIToolbox                     0x00007fff89f4d5f3 ReceiveNextEventCommon + 310
                                  47  com.apple.HIToolbox                     0x00007fff89f4d4ac BlockUntilNextEventMatchingListInMode + 59
                                  48  com.apple.AppKit                        0x00007fff82647eb2 _DPSNextEvent + 708
                                  49  com.apple.AppKit                        0x00007fff82647801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
                                  50  com.apple.AppKit                        0x00007fff82af1718 -[NSScroller trackKnob:] + 1830
                                  51  com.apple.AppKit                        0x00007fff82aef850 -[NSScroller mouseDown:] + 936
                                  52  com.apple.AppKit                        0x00007fff827413a7 -[NSWindow sendEvent:] + 5409
                                  53  com.apple.AppKit                        0x00007fff82676afa -[NSApplication sendEvent:] + 4719
                                  54  com.adobe.Photoshop                     0x0000000101921919 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17610681
                                  55  com.adobe.Photoshop                     0x0000000101920b7f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17607199
                                  56  com.apple.AppKit                        0x00007fff82882e06 -[NSApplication _realDoModalLoop:peek:] + 509
                                  57  com.apple.AppKit                        0x00007fff82880951 -[NSApplication runModalForWindow:] + 129
                                  58  com.apple.AppKit                        0x00007fff82ae6112 -[NSSavePanel runModal] + 318
                                  59  com.adobe.Photoshop                     0x000000010192f56e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17667086
                                  60  com.adobe.Photoshop                     0x00000001005b3050 0x100000000 + 5976144
                                  61  com.adobe.Photoshop                     0x0000000100c4dcc5 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4160357
                                  62  com.adobe.Photoshop                     0x00000001005b3f4a 0x100000000 + 5979978
                                  63  com.adobe.Photoshop                     0x0000000100c51b02 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4176290
                                  64  com.adobe.Photoshop                     0x000000010061b102 boost::system::system_error::what() const + 338690
                                  65  com.adobe.Photoshop                     0x00000001006145b7 boost::system::system_error::what() const + 311223
                                  66  com.adobe.Photoshop                     0x0000000100614674 boost::system::system_error::what() const + 311412
                                  67  com.adobe.Photoshop                     0x00000001005b0c02 0x100000000 + 5966850
                                  68  com.adobe.Photoshop                     0x00000001005b77ec 0x100000000 + 5994476
                                  69  com.adobe.Photoshop                     0x00000001005ad3ae 0x100000000 + 5952430
                                  70  com.adobe.Photoshop                     0x000000010001faa2 0x100000000 + 129698
                                  71  com.adobe.Photoshop                     0x00000001019202d4 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17604980
                                  72  com.apple.Foundation                    0x00007fff85f13bc5 __NSFireTimer + 114
                                  73  com.apple.CoreFoundation                0x00007fff81570bb8 __CFRunLoopRun + 6488
                                  74  com.apple.CoreFoundation                0x00007fff8156ed8f CFRunLoopRunSpecific + 575
                                  75  com.apple.HIToolbox                     0x00007fff89f4d7ee RunCurrentEventLoopInMode + 333
                                  76  com.apple.HIToolbox                     0x00007fff89f4d551 ReceiveNextEventCommon + 148
                                  77  com.apple.HIToolbox                     0x00007fff89f4d4ac BlockUntilNextEventMatchingListInMode + 59
                                  78  com.apple.AppKit                        0x00007fff82647eb2 _DPSNextEvent + 708
                                  79  com.apple.AppKit                        0x00007fff82647801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
                                  80  com.apple.AppKit                        0x00007fff8260d68f -[NSApplication run] + 395
                                  81  com.adobe.Photoshop                     0x0000000101920402 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17605282
                                  82  com.adobe.Photoshop                     0x000000010192266e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17614094
                                  83  com.adobe.Photoshop                     0x00000001005ae27c 0x100000000 + 5956220
                                  84  com.adobe.Photoshop                     0x00000001007b074f boost::system::system_error::what() const + 1999183
                                  85  com.adobe.Photoshop                     0x00000001007b0999 boost::system::system_error::what() const + 1999769
                                  86  com.adobe.Photoshop                     0x000000010054b24c 0x100000000 + 5550668
                                  Thread 1:  Dispatch queue: com.apple.libdispatch-manager
                                  0   libSystem.B.dylib                       0x00007fff890ddc0a kevent + 10
                                  1   libSystem.B.dylib                       0x00007fff890dfadd _dispatch_mgr_invoke + 154
                                  2   libSystem.B.dylib                       0x00007fff890df7b4 _dispatch_queue_invoke + 185
                                  3   libSystem.B.dylib                       0x00007fff890df2de _dispatch_worker_thread2 + 252
                                  4   libSystem.B.dylib                       0x00007fff890dec08 _pthread_wqthread + 353
                                  5   libSystem.B.dylib                       0x00007fff890deaa5 start_wqthread + 13
                                  Thread 2:
                                  0   libSystem.B.dylib                       0x00007fff890ffa6a __semwait_signal + 10
                                  1   libSystem.B.dylib                       0x00007fff89103881 _pthread_cond_wait + 1286
                                  2   MultiProcessor Support                  0x000000011dc380f3 main + 8403
                                  3   MultiProcessor Support                  0x000000011dc381b0 main + 8592
                                  4   MultiProcessor Support                  0x000000011dc54f50 main + 126768
                                  5   libSystem.B.dylib                       0x00007fff890fdfd6 _pthread_start + 331
                                  6   libSystem.B.dylib                       0x00007fff890fde89 thread_start + 13
                                  Thread 3:
                                  2   ...ple.CoreServices.CarbonCore          0x00007fff812b3d87 TSWaitOnCondition + 118
                                  3   ...ple.CoreServices.CarbonCore          0x00007fff81222ff8 TSWaitOnConditionTimedRelative + 177
                                  4   ...ple.CoreServices.CarbonCore          0x00007fff8121cefb MPWaitOnQueue + 215
                                  5   com.adobe.ACE                           0x000000010514b2c9 0x105112000 + 234185
                                  6   com.adobe.ACE                           0x000000010514a5da 0x105112000 + 230874
                                  7   ...ple.CoreServices.CarbonCore          0x00007fff811f50d1 PrivateMPEntryPoint + 63
                                  8   libSystem.B.dylib                       0x00007fff890fdfd6 _pthread_start + 331
                                  9   libSystem.B.dylib                       0x00007fff890fde89 thread_start + 13
                                  Thread 4:
                                  0   libSystem.B.dylib                       0x00007fff890dea2a __workq_kernreturn + 10
                                  1   libSystem.B.dylib                       0x00007fff890dee3c _pthread_wqthread + 917
                                  2   libSystem.B.dylib                       0x00007fff890deaa5 start_wqthread + 13
                                  Thread 5:
                                  1   libSystem.B.dylib                       0x00007fff890ff8f9 nanosleep + 148
                                  2   com.adobe.PSAutomate                    0x00000001233449cb ScObjects::Thread::sleep(unsigned int) + 59
                                  3   com.adobe.PSAutomate                    0x000000012332a7c9 ScObjects::BridgeTalkThread::run() + 169
                                  4   com.adobe.PSAutomate                    0x0000000123344d36 ScObjects::Thread::go(void*) + 166
                                  Thread 6:
                                  2   com.adobe.ape.engine                    0x000000013d3e7c0d APXGetHostAPI + 2516093
                                  3   com.adobe.ape.engine                    0x000000013d195ec1 APXGetHostAPI + 83761
                                  4   com.adobe.ape.engine                    0x000000013d3e7cd1 APXGetHostAPI + 2516289
                                  5   com.adobe.ape.engine                    0x000000013d3e7d4a APXGetHostAPI + 2516410
                                  6   com.adobe.ape.engine                    0x000000013d3e7e79 APXGetHostAPI + 2516713
                                  7   libSystem.B.dylib                       0x00007fff890fdfd6 _pthread_start + 331
                                  8   libSystem.B.dylib                       0x00007fff890fde89 thread_start + 13
                                  Thread 7:
                                  Thread 8:
                                  0   libSystem.B.dylib                       0x00007fff890c4d7a mach_msg_trap + 10
                                  1   libSystem.B.dylib                       0x00007fff890c53ed mach_msg + 59
                                  2   com.apple.CoreFoundation                0x00007fff8156f902 __CFRunLoopRun + 1698
                                  3   com.apple.CoreFoundation                0x00007fff8156ed8f CFRunLoopRunSpecific + 575
                                  4   com.apple.CoreMediaIOServices           0x00007fff8654f5f7 MIO::DAL::RunLoop::OwnThread(void*) + 147
                                  5   com.apple.CoreMediaIOServices           0x00007fff865511c2 CAPThread::Entry(CAPThread*) + 140
                                  6   libSystem.B.dylib                       0x00007fff890fdfd6 _pthread_start + 331
                                  7   libSystem.B.dylib                       0x00007fff890fde89 thread_start + 13
                                  Thread 9:
                                  0   libSystem.B.dylib                       0x00007fff890c4dda semaphore_timedwait_signal_trap + 10
                                  1   libSystem.B.dylib                       0x00007fff89103772 _pthread_cond_wait + 1015
                                  2   com.adobe.ape.engine                    0x000000013d3e7bd0 APXGetHostAPI + 2516032
                                  3   com.adobe.ape.engine                    0x000000013d3ffddb APXGetHostAPI + 2614859
                                  Thread 10:
                                  3   com.adobe.ape.engine                    0x000000013d57a2c3 APXGetHostAPI + 4164403
                                  Thread 11:
                                  0   libSystem.B.dylib                       0x00007fff89108956 recvfrom + 10
                                  1   ServiceManager-Launcher.dylib           0x000000012445e5ec Invoke + 45721
                                  2   ServiceManager-Launcher.dylib           0x000000012445d813 Invoke + 42176
                                  3   ServiceManager-Launcher.dylib           0x000000012445cbe0 Invoke + 39053
                                  4   ServiceManager-Launcher.dylib           0x000000012445cc66 Invoke + 39187
                                  5   ServiceManager-Launcher.dylib           0x000000012445830f Invoke + 20412
                                  6   ServiceManager-Launcher.dylib           0x0000000124458616 Invoke + 21187
                                  7   ServiceManager-Launcher.dylib           0x0000000124458cd7 Invoke + 22916
                                  8   ServiceManager-Launcher.dylib           0x0000000124458f41 Invoke + 23534
                                  9   ServiceManager-Launcher.dylib           0x000000012445b61d Invoke + 33482
                                  10  ServiceManager-Launcher.dylib           0x000000012445b775 Invoke + 33826
                                  11  ServiceManager-Launcher.dylib           0x000000012445bfb2 Invoke + 35935
                                  12  ServiceManager-Launcher.dylib           0x000000012445c0ad Invoke + 36186
                                  13  ServiceManager-Launcher.dylib           0x000000012444ed6b Login + 480
                                  14  ServiceManager-Launcher.dylib           0x00000001244527ad Login + 15394
                                  15  ServiceManager-Launcher.dylib           0x000000012445c412 Invoke + 37055
                                  16  ServiceManager-Launcher.dylib           0x000000012445e253 Invoke + 44800
                                  17  libSystem.B.dylib                       0x00007fff890fdfd6 _pthread_start + 331
                                  18  libSystem.B.dylib                       0x00007fff890fde89 thread_start + 13
                                  Thread 12:
                                  4   com.apple.CoreFoundation                0x00007fff8156eb16 CFRunLoopRun + 70
                                  5   com.apple.DesktopServices               0x00007fff855aa326 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 514
                                  6   ...ple.CoreServices.CarbonCore          0x00007fff811f50d1 PrivateMPEntryPoint + 63
                                  Thread 13:
                                  Thread 14:  com.apple.CFSocket.private
                                  0   libSystem.B.dylib                       0x00007fff89108932 select$DARWIN_EXTSN + 10
                                  1   com.apple.CoreFoundation                0x00007fff81591468 __CFSocketManager + 824
                                  2   libSystem.B.dylib                       0x00007fff890fdfd6 _pthread_start + 331
                                  3   libSystem.B.dylib                       0x00007fff890fde89 thread_start + 13
                                  Thread 0 crashed with X86 Thread State (64-bit):
                                    rax: 0x0000000000000000  rbx: 0x0000000123679000  rcx: 0x00007fff5fbf80d8  rdx: 0x0000000000000000
                                    rdi: 0x0000000000000925  rsi: 0x0000000000000006  rbp: 0x00007fff5fbf80f0  rsp: 0x00007fff5fbf80d8
                                     r8: 0x0000000000000e03   r9: 0x0000000000000000  r10: 0x00007fff8910f0fa  r11: 0x0000000000000202
                                    r12: 0x0000000000000000  r13: 0x0000000107b08408  r14: 0x0000000106bb0000  r15: 0x00000001236790c0
                                    rip: 0x00007fff891130b6  rfl: 0x0000000000000202  cr2: 0x000000012367b000
                                  Binary Images:
                                         0x100000000 -        0x10333cfff +com.adobe.Photoshop 13.0.0 (20120315.r.428) <6A87A703-3170-CA73-8C77-35C282C4E264> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                                         0x1039bf000 -        0x1039bffff  libgenkit.dylib ??? (???) <3A91C7FD-2FA1-9BA5-C409-B83C7DCCA1D8> /usr/lib/libgenkit.dylib
                                         0x1039c2000 -        0x1039eeff7 +libtbb.dylib ??? (???) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbb.dylib
                                         0x103a05000 -        0x103a13ff3 +libtbbmalloc.dylib ??? (???) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbbmalloc.dylib
                                         0x103a27000 -        0x103a2efff  org.twain.dsm 1.9.4 (1.9.4) <92859D8B-FC2A-2932-C510-AB6F6478A546> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                                         0x103a36000 -        0x103a50ff7 +com.adobe.ahclientframework 1.7.0.56 (1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                         0x103a59000 -        0x103a5fff7  com.apple.agl 3.0.12 (AGL-3.0.12) <E5986961-7A1E-C304-9BF4-431A32EF1DC2> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                         0x103a66000 -        0x103c74fff +com.adobe.owl AdobeOwl version 4.0.93 (4.0.93) <CB035C4D-044D-4004-C887-814F944E62ED> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                         0x103cb5000 -        0x1040fbff7 +com.adobe.MPS AdobeMPS 5.8.0.19463 (5.8.0.19463) <8A4BA3B2-6F6A-3958-ABDE-C3E8F21373B0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                         0x104177000 -        0x1044d0ff7 +com.adobe.AGM AdobeAGM 4.26.17.19243 (4.26.17.19243) <E96C804B-158B-D4A2-9A64-482F9ADC29D0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                         0x104539000 -        0x10489afef +com.adobe.CoolType AdobeCoolType 5.10.31.19243 (5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                         0x1048e7000 -        0x10490fff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                         0x104916000 -        0x104942fff +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.7.101.18636 (3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                                         0x104965000 -        0x104ab2ff7 +com.winsoft.wrservices WRServices 5.0.0 (5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                         0x104b26000 -        0x104b95fef +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <924155A9-D00E-B862-C490-5099BA70B978> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                                         0x104bbc000 -        0x104c15fff +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <BC353D4E-1AE2-3FB5-D3EE-81A09C0C4328> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                                         0x104cb5000 -        0x104d3cff7 +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <5FCA15B4-F721-09C3-B412-1F86D9D7DE9E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                                         0x104da1000 -        0x104dbcff7 +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <BB7B342A-8CBC-4B73-58A2-9B062F590EBC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                                         0x104dd6000 -        0x105013fff +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <6839CFB1-74EE-B205-7D82-ABC5428E0810> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                                         0x105112000 -        0x10528bfff +com.adobe.ACE AdobeACE 2.19.18.19243 (2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                         0x10529e000 -        0x1052bdfff +com.adobe.BIB AdobeBIB 1.2.02.19243 (1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                         0x1052c4000 -        0x1053a8fe7 +com.adobe.amtlib amtlib 6.0.0.75 (6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                         0x1053b9000 -        0x10547efff +com.adobe.JP2K 2.0.0 (2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                                         0x1054cb000 -        0x1054cfff7 +com.adobe.ape.shim 3.3.8.19346 (3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                         0x1054d5000 -        0x105553fff +com.adobe.FileInfo.framework Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 (66.145433) <5C63613F-6BDE-1C29-D3FD-9D292F9ADB12> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                                         0x105564000 -        0x1055c4ff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.3 -c 11 (66.145661) <B475CD07-1024-560D-5BFE-2A6FCE63925C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                         0x1055ce000 -        0x105b26fef +com.nvidia.cg 2.2.0006 (???) /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/Cg.framework/Cg
                                         0x106183000 -        0x1061f1fef +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                         0x106245000 -        0x10626affe +adobepdfsettings ??? (???) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
                                         0x1062a5000 -        0x1062a9ff7 +com.adobe.AdobeCrashReporter 6.0 (6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                         0x1062af000 -        0x10645ffef +com.adobe.PlugPlug 3.0.0.383 (3.0.0.383) <908DBB12-D2AC-1844-BD2A-F1C483424917> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                                         0x106516000 -        0x106536fff +com.adobe.AIF AdobeAIF 3.0.00 (3.0.00) <DC3301F2-FC6E-70C7-3927-B0DD024210D6> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ocl.framework/Versions/A/aif_ocl
                                         0x106550000 -        0x10660dfff +com.adobe.AdobeExtendScript ExtendScript 4.2.12 (4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                                         0x106657000 -        0x106705fef +com.adobe.AdobeScCore ScCore 4.2.12 (4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                         0x106742000 -        0x10683cfe7 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.7.101.18636 (3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                         0x1068e0000 -        0x106b29fe7 +com.adobe.linguistic.LinguisticManager 6.0.0 (17206) <301AAE8E-BA78-230E-9500-FCCA204B49CB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                                         0x106bac000 -        0x106bacff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
                                         0x106bf0000 -        0x106bf2fef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                         0x1081ea000 -        0x1081f9fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <1718111B-FC8D-6C8C-09A7-6CEEB0826A66> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                         0x10a2bd000 -        0x10a2d4fe7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <1A440248-D188-CA5D-8C20-5FA33647DE93> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                         0x10a2d8000 -        0x10a2f9fef  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <76503A7B-58B6-64B9-1207-0C273AF47C1C> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                         0x10a2fd000 -        0x10a30ffff  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <00E29B30-3877-C559-85B3-66BAACBE005B> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                         0x10a313000 -        0x10a314fff  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <84C660E9-8370-79D1-2FC0-6C21C3079C17> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                                         0x10a45e000 -        0x10a45efff +Enable Async IO ??? (???) <F56F1FB2-9CF1-19A8-0D14-885A652B19B7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
                                         0x10a462000 -        0x10a465fff +FastCore ??? (???) <29AAF151-6CC4-28C5-68B8-0F6600A20435> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
                                         0x10a65d000 -        0x10a670ff7 +MeasurementCore ??? (???) <2E842E3B-9E4D-6D59-7E5B-A01979288E4B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/Mea surementCore
                                         0x10a67c000 -        0x10a6a2ff7 +com.adobe.ape 3.3.8.19346 (3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/adbeapecore
                                         0x10b172000 -        0x10b1b8fe7 +com.adobe.pip ??? (6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                                         0x10b26c000 -        0x10b26dfff  ATSHI.dylib ??? (???) <D2881261-24A6-4717-D7F9-DF263ABB30F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                                         0x11db00000 -        0x11db6cfff +MMXCore ??? (???) <B9B6C7FB-CE56-8F6F-664E-DFCBBC5E3ADE> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
                                         0x11dbf3000 -        0x11dc78fff +MultiProcessor Support ??? (???) <467BB668-E9DD-60F4-CAAD-768A98174734> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                                         0x11f260000 -        0x11f264fff  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <917E3DC8-E34D-B130-F61F-50808466E674> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                                         0x11f269000 -        0x11f26fff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <C35BDA60-35FC-4BE7-B378-DCC73D99E2C9> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                         0x11f274000 -        0x11f2b1fff  com.apple.DP.ScreenInputDevice 15.0 (15.0) <69919162-3E04-C270-B8AB-8E26634D4BBB> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
                                         0x122606000 -        0x1226f7fff +com.adobe.AdbeScriptUIFlex ScriptUIFlex 6.2.29 (6.2.29.18602) <2BD3388F-976E-0B1C-55DB-B97A5AF95724> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/AdbeScriptUIFlex
                                         0x12277b000 -        0x1227c1fff +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 6.0.0.24 (6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/updaternotifications.framework/Versions/A/UpdaterNotification s
                                         0x123200000 -        0x12345bff7 +com.adobe.PSAutomate 13.0 (13.0) <6EE89DAF-28E8-B15F-1C4B-18D8D19F6452> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Scri ptingSupport
                                         0x12356d000 -        0x1235e7fef +com.adobe.adobe_caps adobe_caps 6.0.29.0 (6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                                         0x123da8000 -        0x123daefe7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <87272933-FB21-81D0-00E6-92BC3D7583FB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
                                         0x124097000 -        0x1240bdfff  GLRendererFloat ??? (???) <38621D22-8F49-F937-851B-E21BD49A8A88> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                                         0x1241c5000 -        0x1242abfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <2D39CB30-54D9-B03E-5FCF-E53122F87484> /usr/lib/libcrypto.0.9.7.dylib
                                         0x124303000 -        0x12432cfef  com.apple.mio.DAL.VDC_4 140.0 (1496) <E22DEEC2-EE3D-03AD-9E02-BDE03CE73588> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Cont ents/MacOS/VDC
                                         0x124449000 -        0x124474fff +ServiceManager-Launcher.dylib 389.0.0 (compatibility 2.5.0) <7AE35754-3413-206D-4B92-579AAA25B4F8> /Library/Application Support/Adobe/CS6ServiceManager/lib/ServiceManager-Launcher.dylib
                                         0x1252a2000 -        0x125435fe7  GLEngine ??? (???) <BCE83654-81EC-D231-ED6E-1DD449B891F2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                                         0x125466000 -        0x125889fef  libclh.dylib 3.1.1 C  (3.1.1) <432F5475-F934-92A0-FB49-78F03DA82176> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
                                         0x13d14d000 -        0x13e0d2fd7 +com.adobe.ape.engine 3.3.8.19346 (3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS /adbeapeengine
                                         0x200000000 -        0x200787fe7  com.apple.GeForceGLDriver 1.6.36 (6.3.6) <4F23289A-D45A-0630-8D7F-4C35A4D2AA00> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
                                      0x7fff5fc00000 -     0x7fff5fc3be0f  dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
                                      0x7fff80066000 -     0x7fff8007aff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                      0x7fff800ba000 -     0x7fff800d0fe7  com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                      0x7fff8028c000 -     0x7fff802f6fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                      0x7fff80305000 -     0x7fff8030cfff  com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                      0x7fff80312000 -     0x7fff8031dff7  com.apple.HelpData 2.0.5 (34.1.1) <24DC6CD3-02B7-9332-FF6D-F0C545857B55> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                                      0x7fff8031e000 -     0x7fff8034ffff  libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                      0x7fff8035f000 -     0x7fff807a3fef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                      0x7fff807a4000 -     0x7fff80859fe7  com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                      0x7fff811ee000 -     0x7fff81522fef  com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                      0x7fff81523000 -     0x7fff8169afe7  com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                      0x7fff8169b000 -     0x7fff81718fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
                                      0x7fff818d6000 -     0x7fff81919fef  libtidy.A.dylib ??? (???) <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
                                      0x7fff8191a000 -     0x7fff82016ff7  com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                      0x7fff82017000 -     0x7fff820a3fef  SecurityFoundation ??? (???) <3F1F2727-C508-3630-E2C1-38361841FCE4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                      0x7fff8215c000 -     0x7fff8231bfff  com.apple.ImageIO.framework 3.0.6 (3.0.6) <2C39859A-043D-0EB0-D412-EC2B5714B869> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                                      0x7fff82340000 -     0x7fff82468ff7  com.apple.MediaToolbox 0.484.60 (484.60) <F921A5E6-E260-03B4-1458-E5814FA1924D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                      0x7fff82469000 -     0x7fff8257fff7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib
                                      0x7fff82580000 -     0x7fff825c1fff  com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                      0x7fff825c2000 -     0x7fff82603fef  com.apple.CoreMedia 0.484.60 (484.60) <6B73A514-C4D5-8DC7-982C-4E4F0231ED77> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
                                      0x7fff82604000 -     0x7fff82ffeff7  com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                      0x7fff82fff000 -     0x7fff82fffff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                      0x7fff83000000 -     0x7fff83003fff  com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                      0x7fff8300d000 -     0x7fff83059fff  libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
                                      0x7fff8305a000 -     0x7fff83060ff7  IOSurface ??? (???) <8E302BB2-0704-C6AB-BD2F-C2A6C6A2E2C3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                      0x7fff83061000 -     0x7fff830f0fff  com.apple.PDFKit 2.5.1 (2.5.1) <38BEE9BB-3716-49BA-7E14-687FE9E066EB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                      0x7fff830f1000 -     0x7fff83100fef  com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                      0x7fff83101000 -     0x7fff83103fff  com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                      0x7fff83104000 -     0x7fff83124fff  com.apple.DirectoryService.Framework 3.6 (621.15) <9AD2A133-4275-5666-CE69-98FDF9A38B7A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                      0x7fff83141000 -     0x7fff83162fe7  libPng.dylib ??? (???) <14F055F9-D7B2-27B2-E2CF-F0A222BFF14D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                                      0x7fff83163000 -     0x7fff8317cfff  com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                      0x7fff8317d000 -     0x7fff831ccff7  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <0731C40D-71EF-B417-C83B-54C3527A36EA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
                                      0x7fff831cd000 -     0x7fff839d7fe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                      0x7fff839d8000 -     0x7fff839e7fff  com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                      0x7fff839e8000 -     0x7fff83a1bff7  libTrueTypeScaler.dylib ??? (???) <B7BA8104-FA18-39A2-56E1-922EE7A660AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                                      0x7fff83a60000 -     0x7fff83a65fff  libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                      0x7fff83c69000 -     0x7fff83c6aff7  com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                      0x7fff83c77000 -     0x7fff83d38fef  com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                      0x7fff83d39000 -     0x7fff83dbbfff  com.apple.QuickLookUIFramework 2.3 (327.7) <73407EAE-6854-E444-37B1-019AAEDEB31B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                      0x7fff83dbc000 -     0x7fff83dc9fe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                      0x7fff83e47000 -     0x7fff84081fef  com.apple.imageKit 2.0.3 (1.0) <9EA216AF-82D6-201C-78E5-D027D85B51D6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                      0x7fff84082000 -     0x7fff8413bfff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
                                      0x7fff8413c000 -     0x7fff8413cff7  com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                      0x7fff8413d000 -     0x7fff84158ff7  com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                      0x7fff84177000 -     0x7fff8417cff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                      0x7fff8417d000 -     0x7fff84183ff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                      0x7fff84184000 -     0x7fff841b4fef  com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                                      0x7fff841b5000 -     0x7fff841c3ff7  libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
                                      0x7fff84214000 -     0x7fff84267ff7  com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                      0x7fff84268000 -     0x7fff842d9ff7  com.apple.AppleVAFramework 4.10.27 (4.10.27) <6CDBA3F5-6C7C-A069-4716-2B6C3AD5001F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                      0x7fff8430a000 -     0x7fff843aafff  com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                      0x7fff843ab000 -     0x7fff843c1fef  libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
                                      0x7fff843c2000 -     0x7fff848c8ff7  com.apple.VideoToolbox 0.484.60 (484.60) <F55EF548-56E4-A6DF-F3C9-6BA4CFF5D629> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                      0x7fff848ec000 -     0x7fff8499cfff  edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                      0x7fff8499d000 -     0x7fff84a37fff  com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                      0x7fff84a38000 -     0x7fff84a98fe7  com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                      0x7fff84a99000 -     0x7fff84aabfe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
                                      0x7fff84af8000 -     0x7fff84b27ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                      0x7fff84b28000 -     0x7fff84db1ff7  com.apple.security 6.1.2 (55002) <772E1B13-8271-02F8-B1FE-023592A7AED7> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                      0x7fff84db2000 -     0x7fff851f9fef  com.apple.RawCamera.bundle 3.7.1 (570) <5AFA87CA-DC3D-F84E-7EA1-6EABA8807766> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                      0x7fff851fa000 -     0x7fff851fbfff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
                                      0x7fff851fc000 -     0x7fff85247fef  com.apple.ImageCaptureCore 1.1 (1.1) <F23CA537-4F18-76FC-8D9C-ED6E645186FC> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                      0x7fff85248000 -     0x7fff8525cfff  libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                      0x7fff8529a000 -     0x7fff8529aff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                      0x7fff8529b000 -     0x7fff852a0fff  libGIF.dylib ??? (???) <5B2AF093-1E28-F0CF-2C13-BA9AB4E2E177> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                                      0x7fff85430000 -     0x7fff85486fe7  libTIFF.dylib ??? (???) <9BC0CAD5-47F2-9B4F-0C10-D50A7A27F461> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                                      0x7fff85487000 -     0x7fff855a6fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
                                      0x7fff855a7000 -     0x7fff855a7ff7  com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                      0x7fff855a8000 -     0x7fff8568dfef  com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                      0x7fff8568e000 -     0x7fff8574bfff  com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                      0x7fff85796000 -     0x7fff857fefff  com.apple.MeshKitRuntime 1.1 (49.2) <4D3045D0-0D50-7053-3A05-0AECE86E39F8> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
                                      0x7fff85818000 -     0x7fff85859fef  com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                      0x7fff8585a000 -     0x7fff858a2ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                      0x7fff858a3000 -     0x7fff85c40fe7  com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                      0x7fff85c41000 -     0x7fff85c44ff7  libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                      0x7fff85e28000 -     0x7fff85e2cff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
                                      0x7fff85e2d000 -     0x7fff85eacfe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                      0x7fff85ead000 -     0x7fff8612ffff  com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                      0x7fff86146000 -     0x7fff861a8fe7  com.apple.datadetectorscore 2.0 (80.7) <5B6AABCA-C75A-D28F-6A2F-59648F0ABFC8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                      0x7fff861a9000 -     0x7fff86367fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <0B4ABA92-C1F0-4548-A157-0CFD65561DA5> /usr/lib/libicucore.A.dylib
                                      0x7fff86368000 -     0x7fff86373ff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                      0x7fff863e7000 -     0x7fff864b2fff  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <86982FBB-B224-CBDA-A9AD-8EE97BDB8681> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
                                      0x7fff864d8000 -     0x7fff864f9fff  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
                                      0x7fff864fa000 -     0x7fff864faff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                      0x7fff8652b000 -     0x7fff86540ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                      0x7fff86541000 -     0x7fff86586fff  com.apple.CoreMediaIOServices 140.0 (1496) <D93293EB-0B84-E97D-E78C-9FE8D48AF58E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
                                      0x7fff865a3000 -     0x7fff868c6fe7  com.apple.JavaScriptCore 6534.57 (6534.57.3) <99973578-D474-3664-1388-61CB47E9D6E9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                      0x7fff8705c000 -     0x7fff870a3fff  com.apple.QuickLookFramework 2.3 (327.7) <A8169A96-FAE6-26B2-A9A9-C78BA5787146> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                      0x7fff870a4000 -     0x7fff870a8ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                      0x7fff870f9000 -     0x7fff87189fff  com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                      0x7fff8718a000 -     0x7fff8719bff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
                                      0x7fff871a4000 -     0x7fff871eeff7  com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                      0x7fff871ef000 -     0x7fff87309fff  libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                      0x7fff87364000 -     0x7fff87364ff7  com.apple.Carbon 150 (152) <23704665-E9F4-6B43-1115-2E69F161FC45> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                      0x7fff87365000 -     0x7fff873d1fe7  com.apple.CorePDF 1.4 (1.4) <06AE6D85-64C7-F9CC-D001-BD8BAE31B6D2> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                      0x7fff873fc000 -     0x7fff87665fff  com.apple.QuartzComposer 4.2 ({156.30}) <C05B97F7-F543-C329-873D-097177226D79> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                      0x7fff87666000 -     0x7fff876a9ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                      0x7fff876aa000 -     0x7fff876acfff  libRadiance.dylib ??? (???) <61631C08-60CC-D122-4832-EA59824E0025> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                                      0x7fff876ad000 -     0x7fff87702ff7  com.apple.framework.familycontrols 2.0.2 (2020) <8807EB96-D12D-8601-2E74-25784A0DE4FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                      0x7fff87703000 -     0x7fff8772bfff  com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                      0x7fff8772c000 -     0x7fff8772fff7  com.apple.securityhi 4.0 (36638) <AEF55AF1-54D3-DB8D-27A7-E16192E0045A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                      0x7fff87730000 -     0x7fff87757ff7  libJPEG.dylib ??? (???) <472D4A31-C1F3-57FD-6453-6621C48B95BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                                      0x7fff87773000 -     0x7fff87774ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                      0x7fff889b7000 -     0x7fff889b8fff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
                                      0x7fff88fa1000 -     0x7fff890abff7  com.apple.MeshKitIO 1.1 (49.2) <C19D0CCD-1DCB-7EDE-76FA-BF74079AFC6A> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
                                      0x7fff890ac000 -     0x7fff890c3fff  com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                      0x7fff890c4000 -     0x7fff89285fef  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
                                      0x7fff892bd000 -     0x7fff892f6ff7  com.apple.MeshKit 1.1 (49.2) <832A074D-7601-F7C9-6D3A-E1C58965C3A1> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
                                      0x7fff892f7000 -     0x7fff8937cff7  com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                      0x7fff893c8000 -     0x7fff894c0ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <44AADE50-15BC-BC6B-BEF0-5029A30766AC> /usr/lib/libiconv.2.dylib
                                      0x7fff8953f000 -     0x7fff895f5ff7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
                                      0x7fff895f6000 -     0x7fff89621ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib
                                      0x7fff89622000 -     0x7fff896f6fe7  com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                                      0x7fff896f7000 -     0x7fff89740ff7  com.apple.securityinterface 4.0.1 (40418.0.1) <9AF33A9F-2D8C-2AE6-868C-EA836C861031> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                      0x7fff89741000 -     0x7fff89741ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                      0x7fff89772000 -     0x7fff897acfff  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <4F2A4397-89BD-DEAC-4971-EE838FFA0964> /usr/lib/libcups.2.dylib
                                      0x7fff897e0000 -     0x7fff89829fef  libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                      0x7fff8992f000 -     0x7fff89a64fff  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                      0x7fff89a65000 -     0x7fff89ba3fff  com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                      0x7fff89c7f000 -     0x7fff89ca4ff7  com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                      0x7fff89ca5000 -     0x7fff89cabff7  com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                      0x7fff89cac000 -     0x7fff89d89fff  com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                      0x7fff89d8a000 -     0x7fff89d8aff7  com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                      0x7fff89dde000 -     0x7fff89e6bfff  com.apple.iLifeMediaBrowser 2.5.5 (468.2.2) <0A7B422E-5D79-9980-2477-05DC2CB5CF7C> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
                                      0x7fff89e6c000 -     0x7fff89ea7fff  com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                      0x7fff89ea8000 -     0x7fff89ecbfff  com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                      0x7fff89ecc000 -     0x7fff89f13ff7  com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                      0x7fff89f14000 -     0x7fff89f1efff  com.apple.DisplayServicesFW 2.3.3 (289) <97F62F36-964A-3E17-2A26-A0EEF63F4BDE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                      0x7fff89f1f000 -     0x7fff8a21dfff  com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                      0x7fff8a21e000 -     0x7fff8a224fff  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <D2F8C7E3-CBA1-2E66-1376-04AA839DABBB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
                                      0x7fff8a2a6000 -     0x7fff8a416fff  com.apple.QTKit 7.7 (1791) <1BC285ED-A1EE-4A80-D264-C93803C439DD> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                      0x7fff8a41c000 -     0x7fff8a42dfff  com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
                                      0x7fff8a42e000 -     0x7fff8a46cfe7  libFontRegistry.dylib ??? (???) <395D7C0D-36B5-B353-0DC8-51ABC0B1C030> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                      0x7fff8a46d000 -     0x7fff8a4ebff7  com.apple.CoreText 151.13 (???) <5C6214AD-D683-80A8-86EB-328C99B75322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                                      0x7fff8a4ec000 -     0x7fff8a5aefe7  libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                      0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
                                  • 14. Re: New CS6 is crashing and now my old CS2 is crashing too.
                                    Level 7
                                    CS2 report doesn't make sense - something corrupted the stack.
                                    CS6 report makes sense - you're crashing in MacOS filesystem code.
                                    Usually that is caused by corrupt disk structures, which can sometimes be repeaired with Disk Utility.
                                    Also, Apple says they made this crashing code much better in 10.8 (but it still crashes sometimes).
                                    • 15. Re: New CS6 is crashing and now my old CS2 is crashing too.
                                      gator soup Level 4
                                      Restarted as a different user and CS6 seemed to be fine... CS2 crashed immediately.
                                      You could have a CS2 conflict (like a bad 3rd party plugin) or corruption or bad font (all OS/Adobe updates ran?)
                                      What do you mean by a bad system install?
                                      something in your installed software is corrupted and/or buggy
                                      at this point, since it doesn't clear in a New User, i would download the latest Apple "Combo Updater"
                                      http://support.apple.com/kb/DL1399
                                      and install it on top of your system (THEN run Apple Software Update and all Adobe> Help> Updates)...
                                      reboot test in new user
                                      if you need CS2, you possibly uninstall/reinstall Photoshop CS2, and test in new user
                                      and let us know the results...
