I am trying to insert page break to some of my topics so they would start to a new page in printed documentation, but page break doesn't seem to work. I wonder why and what's the workaround to solve this issue, if any?
For example:
Within a topic, I have:
Heading 1
Heading 2
I wanted Heading 2 to be in the next page in printed documentation. Is that possible at all?
This was a variation on a method that I sent tanborj and it was later found not to be entirely satisfactory. I have since sent this solution that provides an easy alternative to the method in RoboHelp which has a bug in it.
Open your CSS in a text editor. Add this
.break { page-break-before: always; }
(You can change the name of the first instance of "break" to anything you like but no spaces).
I believe it is covered in RoboHelp Tour for RoboHelp 9 on my site.
It was designed for printing topics in online help rather than printed docs. Think it does work there also though.
Check my site. Post back if not resolved. I will look in morning. Late here now.
Thanks, Peter.
It works but there's a little adjustment on the next page when I insert a page break.
For example, if I have two headings:
About page break <page break>
Using page break
The Using page break heading will go to the next page, but it would go a little lower in the page instead going on top of the page. See screenshot below.
If I insert a page break like this:
About page break
<page break>Using page break
...it just wouldn't work.
There is a macro on my site that was designed for a similar problem.
http://www.grainge.org/pages/authoring/word/word_macros.htm
Not sure if it will help here but if it doesn't you can close the document without saving.
Didn't work
Recreate that in a small demo project. See the Contact page on my site and send the project as instructed there. Do make sure you include a link to this thread and please do not email the project direct.
Project sent.
Found a solution (and so simple, really. Why I haven’t thought of that at the very beginning). Good grief!
When page break is inserted at the end of the paragraph like this:
The html code will be like this:
What I did is I remove the page break tag and put it at the end of the paragraph like this:
…and that solves the problem.
it's just a painful solution though especially when you have hundreds of pages that you have to do it manually.
It works both for both printed and online help. When I say online help, that means that the appearance on online help is perfectly fine. This solves the issue. Thank you so much, Peter. You're really helpful
