Hello.
I'm using ColdFusion 9 and I have a question.
When we have a form with required fields coded like this:
<cfinput ... required="yes" message="Enter a value 1" />
<cfinput ... required="yes" message="Enter a value 2" />
<cfinput ... required="yes" message="Enter a value 3" />
When user sumbits this form he will se an alert window:
Enter a value 1
Enter a value 2
Enter a value 3
How can I make it other way so then one single message is outputted like:
"Enter values for all required fields"
Not one message for each required field.
Sorry for my imperfect English. Thank you.
I don't think the automatic validation built into cfinput will allow you to do that. You should create your own validation. Here is an example to get you started:
<script language="javascript" type="text/javascript">
function validate() {
// the values of the required fields
var a_val = document.getElementById("a_id").value;
var b_val = document.getElementById("b_id").value;
var c_val = document.getElementById("c_id").value;
// trim any leading and trailing s
...Copy link to clipboard
// trim any leading and trailing spaces
a_val = a_val.replace(/^\s+|\s+$/g,'');
b_val = b_val.replace(/^\s+|\s+$/g,'');
c_val = c_val.replace(/^\s+|\s+$/g,'');
// validate
if(a_val=='' || b_val=='' || c_val=='') {
alert('You must enter values for the required fields a, b and c');
return false;
else
return true;
</script>
<cfif isdefined("form.sbmt")>
<cfdump var="#form#">
</cfif>
<cfform onsubmit="return validate()">
a:<cfinput name="a" id ="a_id" type="text">
b:<cfinput name="b" id ="b_id" type="text">
c:<cfinput name="c" id ="c_id" type="text">
<cfinput name="sbmt" type="submit" value="send"/>
</cfform>
This is just a basic validation script to illustrate the principle. You may of course make it as sophisticated as you want, or even import specialized Javascript libraries to do the validation for you.
Thank you very much, that's the very thing I needed.
So, thanks to BKBK, I created an universal solution to this. Here it goes if anyone'll need it.
Here is cffunction that generates validation code:
cffunction name="generate_validation" access="public" returntype="string">
<cfargument name="fieldList" type="string" required="yes">
<cfoutput>
<cfsavecontent variable="scr">
<cfloop list="#fieldList#" index="i">
var val_#i# = document.getElementById("#i#").value;
val_#i# = val_#i#.replace(/^\s+|\s+$/g,'');
if (val_#i# == '')
document.getElementById("#i#").focus();
alert('Please fill all required fields!');
return false;
</cfloop>
return true;
</cfsavecontent>
</cfoutput>
<cfreturn scr>
</cffunction>
And it works from .cfm page like this:
<cfinvoke component="iCFC.udfs" method="generate_validation" returnvariable="scr" fieldList="name,image,code,manual_create_order" />
<cfoutput>
<script>
#scr#
</script>
</cfoutput>
<cfform onsubmit="return validate()" action="contents/service/process_service.cfm" name="fProcess" method="post" >
