Bonjour,
J'ai la fenetre de mise a jour Flash qui revient sans cesse, j'ai desinstallé Flash et je l'ai remis, cela fonctionne, mais cette fenêtre de mise a jour revient quand même plusieurs fois par jour.
Le problème se pose sur les 3 PC
Windows 7 et IE 9
Hello,
I have the window to update Flash keeps coming back, I uninstalled Flash and I gave it, it works, but the window update still returns several times a day.
The problem is the 3 PC
Windows 7 and IE 9
Sorry, I do not understand - Windows Update is not used to update Flash Player on Windows 7 (it is on Windows 8).
If I misunderstood, can you post a screenshot of that update request?
Thank you, here is a picture window that appears constantly .... and I'm not the only one having this trouble I have windows 7 and IE9
And does that pop-up still reappear if you click 'Oui'.
I click YES, of course, the update moves but the window back then and I even if again yes I always come back to the window
I have installed this update 10 times that day and it always come back
Can you try the link at the bottom of that notification "changer quand ces notifications apparaissent".
Hello, after a Windows update, the problem appears finally over .....
thank you for the follow
Dan, could you state what update fixed the issue? (you can see it in add/remove programs, or whatever it is called nowadays)
