Merge or flatten layers
Apr 12, 2012 Apr 12, 2012
This question was posted in response to the following article: http://help.adobe.com/en_US/acrobat/pro/using/WS58a04a822e3e50102bd615109794195ff-7c58.w.html
Create PDFs
30.7K
Community Expert , Apr 12, 2012 Apr 12, 2012
View > Navigation Panels > Layers
Guest
Adobe Acrobat 9 Pro - I want to flatten or merge layers. The help says "Click the Layer Button". Well WHERE IS IT OR WHAT DOES IT LOOK LIKE??? I get so frustrated that the help says something like that and doesn't give any clue where it is or what it looks like. A search for Layer Button doesn't help either. I've been turning toolbars on and off and searching for an hour to try and find the elusive Layer Button. Frankly I think your help files are just horrible.
No need to go anywhere near the menus - it's on the sidebar:
You can control which panels are available by right-clicking the sidebar.
Dec 11, 2012 Dec 11, 2012
Thank you for the clarification!
I agree with jrt-tn that the embedded help is lacking in visual clues.
Guest
Dec 21, 2012 Dec 21, 2012
in Acrobat Pro XI I found the layers button finally, but it's greyed out-- I have a stamp and text boxes-- are they not layers? If not, how else to flatten without printing to pdf--or is that the only way, as cumbersome as it is?
They may or may not be on layers. Everything in a PDF can be on a layer potentially.
Confusingly, flattening in a PDF can be at least three different things. Flattening layers is really nothing but removing the names of layers. Then there is flattening transparency, and flattening comments.
For a simple way of flattening annotations (which includes form fields), you can use this handy free JavaScript-based tool: http://www.uvsar.com/projects/acrobat/flattener/
Aug 31, 2016 Aug 31, 2016
Can this be scripted with javascript via a button trigger? I would like to flatten layers. You can do it from the panel easily and I would think you could do it from a button as you can "execute menu item" for most of the navigation.
Yes, it can be done using the "Flatten Layers" Preflight Profile, like this:
var oProfile = Preflight.getProfileByName("Flatten Layers");
if (oProfile != undefined)
    this.preflight(oProfile);
Guest
Feb 09, 2017 Feb 09, 2017
try67-
I've added the above script to a button but had no luck.  I'm a newbie so I don't fully understand all of it.  Can you translate the script so that I can determine what modification I need to make?  I'm unsure of what oProfile means exactly and the .getProfileByName.  Is "Flatten Layers" the profile name that already exists in acrobat?
Jason
Don't worry about what oProfile means. You just need to create the "Flatten Layers" Preflight Profile and then it should work.
Create a new profile and then add to it the following Fixup command: Discard hidden layer content and flatten visible layers.
Save the profile as "Flatten Layers" and then the code should work.
Guest
Feb 10, 2017 Feb 10, 2017
This was very helpful.  I didn't realize that creating the profile was easily done through the preflight tool nor that the "Fixup" command was a component of the tool.  The code worked perfectly, thank you.
