1. Re: Only import sound - another problem the image flickering
Stan Jones Dec 24, 2012 5:10 AM (in response to steenmikkelsen2)Confirm that you are trying to export NTSC source as PAL. I don't think it is that simple.
2. Re: Only import sound - another problem the image flickering
John T Smith Dec 24, 2012 8:21 AM (in response to steenmikkelsen2)I don't think Encore is the right place to try and convert NTSC to PAL
Convert NTSC <--> PAL http://forums.adobe.com/thread/995779
3. Re: Only import sound - another problem the image flickering
steenmikkelsen2 Dec 24, 2012 1:49 PM (in response to John T Smith)Why it you think the video is an NTHS ???then i look at the properties of the file it's look for me as an. PAL.. Please tell me.?
4. Re: Only import sound - another problem the image flickering
John T Smith Dec 24, 2012 2:03 PM (in response to steenmikkelsen2)The source in your screen shots is 720x480 which is an NTSC size
5. Re: Only import sound - another problem the image flickering
steenmikkelsen2 Dec 24, 2012 3:53 PM (in response to John T Smith) -
6. Re: Only import sound - another problem the image flickering
Stan Jones Dec 24, 2012 7:02 PM (in response to steenmikkelsen2)The image that shows the source as 720x480 shows the source "file" as "A Sequence." Is that image dynamic link? What happens if you "import as timeine" the file you show the properties of that are 720x576.
What are you Premiere sequence settings?
7. Re: Only import sound - another problem the image flickering
Bill Hunt Dec 25, 2012 10:18 AM (in response to steenmikkelsen2)Also, is that AVI a DV-AVI, using the DV/DVC CODEC, or something else? For the Export to AVI, you want the DV PAL setting, and then, as Stanley suggests, Import that DV-AVI as a Timeline, into Encore.
Good luck,
Hunt
8. Re: Only import sound - another problem the image flickering
steenmikkelsen2 Dec 25, 2012 11:23 AM (in response to Bill Hunt)Ok - I have imported from the camera to AVS Video editor via USB, then Adobe Promiere can't capture via USB, but need a FireWire connection, (1394) mabye I shall buy a FireWire adapter sow I can capture direct to Premiere -
is there one of you who can recommend FireWire adapter (1394) that I use with Premiere and my analog camcorder?
9. Re: Only import sound - another problem the image flickering
John T Smith Dec 25, 2012 12:23 PM (in response to steenmikkelsen2)If you really have an ANALOG camcorder, not a DIGITAL camcorder... it will not work with Firewire, since the analog signal must be converted to digital
I am confused, so please post the brand & model camera you have... and maybe a web link to the vendor page so people may determine if you really have an analog or a digital camcorder
10. Re: Only import sound - another problem the image flickering
Neil Wilkes Jan 8, 2013 3:12 AM (in response to steenmikkelsen2)steenmikkelsen2 wrote:
Oh Dear - AVS uses a library called ffmpeg, which is largely based on reverse engineered commercial codecs and is not - ever - guaranteed to be DVD compliant in it's output.
What looks like has happened to me is that the encore project appears to be NTSC (720x480) and I suspect the flickering issues are caused by changing frame rates in that dodgy conversion utility.
Can you please confirm the following:
1 - Project settings in Encore
2 - Camera settings
3 - Settings used in AVS - including codec used?
Analogue to digital via FireWire capture can be done if you have a special box to do this.
