1. Re: Raid 0 for Blackmagic Cinema?
Alex - DV411 Dec 23, 2012 6:38 PM (in response to notex235)How do you plan to bring BMCC images into Pr? That will determine the answer to your RAID question.
Some ideas:
2. Re: Raid 0 for Blackmagic Cinema?
notex235 Dec 23, 2012 8:24 PM (in response to Alex - DV411)I was actually going to export proxy's to edit.
and render final in resolve but raid should increase both applications?
i don't have any problems really with mercury engine though.
3. Re: Raid 0 for Blackmagic Cinema?
ECBowen Dec 27, 2012 2:28 PM (in response to notex235)A 2 Drive Raid 0 should be able to handle those DNG files inside Davinci. The LSI card would probably be the best choice for that price range. Most others would be more expensive and the cheaper far less performance. You might also want to consider looking at Cineform to convert the DNG files. When I did the test here with some sample DNG files from that camera the results were stunning and the differential in AE was near negligible.
Eric
ADK
4. Re: Raid 0 for Blackmagic Cinema?
notex235 Dec 27, 2012 11:52 PM (in response to ECBowen)Essentially I was thinking of that but would it give me the same range as the dng as in lightroom or resolve?
5. Re: Raid 0 for Blackmagic Cinema?
ECBowen Dec 28, 2012 10:25 AM (in response to notex235)Cineform should give you the same color range as DNG if you use the Film Scan 1 or 2.
Eric
ADK
