Huge CPU load/poor performance php zend system written by Flash Builder data wizard
saariko Dec 28, 2012 11:07 AMI am a self-taught AS3/Flex/AIR developer and I have built a system of touchscreen-kiosks running on AIR with remote content managment from an online Flex app.
This is the first time I have done server side stuff, so feel free to correct my question if needed.
Both the AIR apps and the Flex app connect to a mysql database for simple CRUD operations using php scripts and the Zend framework. The kiosks call the server every 30 seconds to update.
All these simple server side php scripts were auto-generated by Flash Builder's data wizard. I did the simple adjusments (gateway.php, amf_config.ini, mysqli connection parameters) and deployed everything to the client's server. This is a a shared-server type.
Now, the system works. But it works slowly. Each create/read/update/delete operation works but I think it should be a lot faster. Also, these operations put a lot of load on the server's cpu. According to the hosting guys, this system opens php-cgi proccesses that take up 40% of the server cpu power, and by doing so slows itself down and other sites hosted on that server.
My questions are:
First of all, is there a problem to begin with or is this performance expexted from the Zend framework? Are the auto-generated scripts written by Flash Builder poorly written and can be optimized? Can this kind of system stay on a shared-hosted-server? Should we move to a VPS server for better performance? Is it posiible that if the tables I created on the mysql database with phpmyadmin weren't optimiatlly built that it would have this kind of impact on performance?
I have been told php cgi is much slower then mod_php or php-fpm (i dont know what any of that is).
I don't know php or mysql. Any kind of help will be much appriciated.
Saar
Here is the script written by Flash Builder: I havn't added anything - just changed the connection parameters.
<?php
class KiosksService {
var $username = "--------";
var $password = "--------";
var $server = "--------";
var $port = "3306";
var $databasename = "--------";
var $tablename = "kiosks";
var $connection;
* The constructor initializes the connection to database. Everytime a request is
* received by Zend AMF, an instance of the service class is created and then the
* requested method is invoked.
public function __construct() {
$this->connection = mysqli_connect(
$this->server,
$this->username,
$this->password,
$this->databasename,
$this->port
$this->throwExceptionOnError($this->connection);
* Returns all the rows from the table.
* Add authroization or any logical checks for secure access to your data
* @return array
public function getAllKiosks() {
$stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename");
$this->throwExceptionOnError();
mysqli_stmt_execute($stmt);
$rows = array();
mysqli_stmt_bind_result($stmt, $row->KioskID, $row->Station, $row->Branch, $row->Chain, $row->Pingdate, $row->Layout, $row->Online, $row->Clips, $row->Extra);
while (mysqli_stmt_fetch($stmt)) {
$row->Pingdate = new DateTime($row->Pingdate);
$rows[] = $row;
$row = new stdClass();
mysqli_stmt_free_result($stmt);
mysqli_close($this->connection);
return $rows;
* Returns the item corresponding to the value specified for the primary key.
* Add authorization or any logical checks for secure access to your data
* @return stdClass
public function getKiosksByID($itemID) {
$stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename where KioskID=?");
mysqli_stmt_bind_param($stmt, 'i', $itemID);
if(mysqli_stmt_fetch($stmt)) {
return $row;
} else {
return null;
* @return stdClass
public function createKiosks($item) {
$stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (Station, Branch, Chain, Pingdate, Layout, Online, Clips, Extra) VALUES (?, ?, ?, ?, ?, ?, ?, ?)");
mysqli_stmt_bind_param($stmt, 'sssssisi', $item->Station, $item->Branch, $item->Chain, $item->Pingdate->toString('YYYY-MM-dd HH:mm:ss'), $item->Layout, $item->Online, $item->Clips, $item->Extra);
$autoid = mysqli_stmt_insert_id($stmt);
return $autoid;
* Updates the passed item in the table.
* @param stdClass $item
* @return void
public function updateKiosks($item) {
$stmt = mysqli_prepare($this->connection, "UPDATE $this->tablename SET Station=?, Branch=?, Chain=?, Pingdate=?, Layout=?, Online=?, Clips=?, Extra=? WHERE KioskID=?");
mysqli_stmt_bind_param($stmt, 'sssssisii', $item->Station, $item->Branch, $item->Chain, $item->Pingdate->toString('YYYY-MM-dd HH:mm:ss'), $item->Layout, $item->Online, $item->Clips, $item->Extra, $item->KioskID);
* Deletes the item corresponding to the passed primary key value from
* the table.
* @return void
public function deleteKiosks($itemID) {
$stmt = mysqli_prepare($this->connection, "DELETE FROM $this->tablename WHERE KioskID = ?");
* Returns the number of rows in the table.
public function count() {
$stmt = mysqli_prepare($this->connection, "SELECT COUNT(*) AS COUNT FROM $this->tablename");
mysqli_stmt_bind_result($stmt, $rec_count);
mysqli_stmt_fetch($stmt);
return $rec_count;
* Returns $numItems rows starting from the $startIndex row from the
* table.
* @return array
public function getKiosks_paged($startIndex, $numItems) {
$stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename LIMIT ?, ?");
mysqli_stmt_bind_param($stmt, 'ii', $startIndex, $numItems);
$rows = array();
$rows[] = $row;
return $rows;
* Utility function to throw an exception if an error occurs
* while running a mysql command.
private function throwExceptionOnError($link = null) {
if($link == null) {
$link = $this->connection;
if(mysqli_error($link)) {
$msg = mysqli_errno($link) . ": " . mysqli_error($link);
throw new Exception('MySQL Error - '. $msg);
