Through Creative Cloud and the Adobe Application Manager, I have downloaded and installed several CS6 programs correctly and without errors or issues. However, I get stuck at 14% during the installation of Dreamweaver. When viewing the log file, I came across the following warning (I have listed the full log file below):
WARNING: DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
The only article I found on this forum which is somewhat close, but not helpful for my situation, is http://forums.adobe.com/message/4827191#4827191
I have done the following to attempt to resolve the issue (I'm using a PC, Windows 7 ultimate):
I know uninstalling the program doesn't typically remove every file, but I'm concerned about running the clean install utility. Should I run that and just copy my Adobe program files beforehand?
Any help would be greatly appreciated. Dreamweaver is the last program I need to install after a long format and install process of my SSD.
Thank you,
Chris
Visit http://www.adobe.com/go/loganalyzer/ for more information
START - Installer Session
RIBS version: 6.2.10.0
Win OS version: 6.1.1.0 64 bit Type: 1
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
CHECK : Another Native OS installer already running
Create Required Folders
Assuming uninstall mode
Lookup for master payload
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
Supported RIBS version range: [0.0.66.0,6.2.10.0]
----------------- CreatePayloadSession: machine is x64 ---------------
[ 3012] Fri Dec 28 07:00:28 2012 INFO
______ Verify Dependency Subscribers ______
BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
{354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: 1 (0,3)
{9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1: 2 (0,6)
{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180: 3 (0,4)
{9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148: 3 (0,4)
{8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0: 4 (1,2)
{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: 5 (1,1)
{EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: 6 (0,1)
{C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0: 6 (0,1)
{DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: 6 (0,1)
{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0: 6 (0,1)
{36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: 7 (3,1)
{EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: 8 (4,1)
{83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: 8 (4,1)
{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: 9 (13,0)
{8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0: 10 (0,0)
{8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0: 10 (0,0)
END Operation order for all session payloads: mediaGroup (requires,satisfies)
Setting property "driverAdobeCode" to: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
Setting property "mediaSignature" to: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
Setting property "removeUserPrefs" to: 1
Overwrite property "userASUPath" to: C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\..\D6
Found payload actions:
Deciding what installer mode to use...
{8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 not installed
{8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 not installed
{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 not installed
BEGIN Setting requested payload actions
Value returned on lookup of payload: {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is: false
Action string for {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is none
Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
Value returned on lookup of payload: {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is: false
Action string for {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is none
Payload {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
Value returned on lookup of payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is: false
[ 3012] Fri Dec 28 07:00:28 2012 WARN
DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is not installed so should not be there in the deployment file
Value returned on lookup of payload: {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 is: true
Action string for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 is none
Value returned on lookup of payload: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 is: true
Action string for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 is none
Value returned on lookup of payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 is: true
Action string for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 is none
Value returned on lookup of payload: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 is: true
Action string for {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 is none
Value returned on lookup of payload: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 is: true
Action string for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 is none
Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: true
Action string for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is none
Value returned on lookup of payload: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 is: true
Action string for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 is none
Value returned on lookup of payload: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 is: true
Action string for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 is none
Value returned on lookup of payload: {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 is: true
Action string for {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 is none
Value returned on lookup of payload: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148 is: true
Action string for {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148 is none
Value returned on lookup of payload: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180 is: true
Action string for {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180 is none
Value returned on lookup of payload: {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1 is: true
Action string for {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1 is none
Value returned on lookup of payload: {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 is: true
Action string for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 is none
END Setting requested payload actions
INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
[ 3012] Fri Dec 28 07:00:29 2012 INFO
BEGIN InstallOperationsQueue Unordered operations
{354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: with operation remove
{36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: with operation remove
{83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: with operation remove
{8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0: with operation remove
{8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0: with operation none
{8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0: with operation none
{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180: with operation remove
{9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148: with operation remove
{9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1: with operation remove
{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: with operation none
{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: with operation remove
{C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0: with operation remove
{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0: with operation remove
{DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: with operation remove
{EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: with operation remove
{EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: with operation remove
END InstallOperationsQueue Unordered operations
BEGIN InstallOperationsQueue Ordered operations
END InstallOperationsQueue Ordered operations
Payloads passed preflight validation.
Call PreSession Custom Hook
{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: with operation none
Calling the custom action code for pre-remove for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
::START TIMER:: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}]
[ 3784] Fri Dec 28 07:00:29 2012 INFO
Installer Operation: PayloadUninstaller
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
Effective AdobeCode for: {83463106-DD1C-4FE5-A61C-DF6715472AD4} is {83463106-DD1C-4FE5-A61C-DF6715472AD4}
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 102.788 milliseconds (0.102788 seconds)
User specified overrideFile:
The csu inventory was not updated for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
Calling the custom action code for pre-remove for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
::START TIMER:: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}]
[ 2624] Fri Dec 28 07:00:29 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
Effective AdobeCode for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} is {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
:: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 101.782 milliseconds (0.101782 seconds) DTR = 157.199 KBPS (0.153515 MBPS)
The csu inventory was not updated for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
Calling the custom action code for pre-remove for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
::START TIMER:: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
[ 1736] Fri Dec 28 07:00:29 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
Effective AdobeCode for: {36682D68-3834-487E-BA49-DFA4AB0A2E32} is {36682D68-3834-487E-BA49-DFA4AB0A2E32}
:: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 102.828 milliseconds (0.102828 seconds)
The csu inventory was not updated for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
Calling the custom action code for pre-remove for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
::START TIMER:: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}]
[ 1804] Fri Dec 28 07:00:29 2012 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Unable to remove payload.
Third party payload completed. Testing return code: 0
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 102.867 milliseconds (0.102867 seconds)
The csu inventory was not updated for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
[ 3012] Fri Dec 28 07:00:30 2012 INFO
Calling the custom action code for pre-remove for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
::START TIMER:: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}]
[ 3052] Fri Dec 28 07:00:30 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
Effective AdobeCode for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} is {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
:: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 109.64 milliseconds (0.10964 seconds)
The csu inventory was not updated for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
Calling the custom action code for pre-remove for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
::START TIMER:: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}]
[ 1848] Fri Dec 28 07:00:30 2012 INFO
:: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 109.692 milliseconds (0.109692 seconds)
Successfully updated the csu inventory for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 return values 0:0
Calling the custom action code for post-remove for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
Calling the custom action code for pre-remove for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
::START TIMER:: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
[ 1556] Fri Dec 28 07:00:30 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
Effective AdobeCode for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} is {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
:: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 98.6255 milliseconds (0.0986255 seconds)
The csu inventory was not updated for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
Calling the custom action code for pre-remove for payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0
::START TIMER:: [Payload Operation :{8706963D-5F48-47CC-998B-DAB70B089DB8}]
[ 3632] Fri Dec 28 07:00:30 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {8706963D-5F48-47CC-998B-DAB70B089DB8}
Effective AdobeCode for: {8706963D-5F48-47CC-998B-DAB70B089DB8} is {8706963D-5F48-47CC-998B-DAB70B089DB8}
:: END TIMER :: [Payload Operation :{8706963D-5F48-47CC-998B-DAB70B089DB8}] took 101.705 milliseconds (0.101705 seconds)
The csu inventory was not updated for payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0
Calling the custom action code for pre-remove for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
::START TIMER:: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}]
[ 4752] Fri Dec 28 07:00:30 2012 INFO
:: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 99.1108 milliseconds (0.0991108 seconds)
The csu inventory was not updated for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148, value of local var is -1
Calling the custom action code for post-remove for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
Calling the custom action code for pre-remove for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
::START TIMER:: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}]
[ 3444] Fri Dec 28 07:00:31 2012 INFO
[ 3012] Fri Dec 28 07:00:31 2012 INFO
:: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 101.476 milliseconds (0.101476 seconds)
The csu inventory was not updated for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180, value of local var is -1
Calling the custom action code for post-remove for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
Calling the custom action code for pre-remove for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
::START TIMER:: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}]
[ 4948] Fri Dec 28 07:00:31 2012 INFO
:: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 102.263 milliseconds (0.102263 seconds)
The csu inventory was not updated for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1, value of local var is -1
Calling the custom action code for post-remove for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
Calling the custom action code for pre-remove for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
::START TIMER:: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}]
[ 2900] Fri Dec 28 07:00:31 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
Effective AdobeCode for: {354D20E6-A25F-4728-9DA6-C9003D8F2928} is {354D20E6-A25F-4728-9DA6-C9003D8F2928}
:: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 103.039 milliseconds (0.103039 seconds)
The csu inventory was not updated for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0, value of local var is -1
Calling the custom action code for post-remove for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
Calling the custom action code for pre-remove for payload CommonUninstall 6.2.10.0
::START TIMER:: [Payload Operation :CommonUninstall]
[ 1904] Fri Dec 28 07:00:31 2012 INFO
Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: CommonUninstall
Effective AdobeCode for: CommonUninstall is CommonUninstall
Uninstalling payload
Payload CommonUninstall 6.2.10.0: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
INSTALLDIR property not found in database
Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\CommonUninstall.db
UninstallSeq property not found in database
[ 1904] Fri Dec 28 07:00:31 2012 ERROR
DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\Keyfiles". Error 145 The directory is not empty.(Seq 1)
[ 1904] Fri Dec 28 07:00:31 2012 WARN
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 1)
DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc\CreativeCloud-CS6-Win-GM". Error 145 The directory is not empty.(Seq 2)
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 2)
DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc\CreativeCloud-CS6-Mac-GM". Error 145 The directory is not empty.(Seq 3)
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 3)
DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc\AMT". Error 145 The directory is not empty.(Seq 4)
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 4)
DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc". Error 145 The directory is not empty.(Seq 5)
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 5)
DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\PCF". Error 145 The directory is not empty.(Seq 6)
DW063: Command ARKDeleteDirectoryCommand failed.(Seq 6)
Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\CommonUninstall.db
Physical payload uninstall result:0
:: END TIMER :: [Payload Operation :CommonUninstall] took 102.76 milliseconds (0.10276 seconds) DTR = 311.406 KBPS (0.304107 MBPS)
The csu inventory was not updated for payload CommonUninstall 6.2.10.0, value of local var is -1
Calling the ROLLBACK custom action code for pre-remove for payload CommonUninstall 6.2.10.0
No operation. We're done:
Updating driver data - Action: Remove driver entry
Updating driver data successful. Driver entry was removed. ARP estimated size 106232KB
[ 3012] Fri Dec 28 07:00:33 2012 INFO
Total components installed: 0
Total components repaired: 0
Successfully removed 1 component:
- Adobe Dreamweaver Widget Browser
Call PostSession Custom Hook
Begin cleaning up local media db.
[ 3012] Fri Dec 28 07:00:34 2012 INFO
Done cleaning up local media db.
:: END TIMER :: [Total Timer] took 6975.09 milliseconds (6.97509 seconds) DTR = 32824.2 KBPS (32.0549 MBPS)
[ 3012] Fri Dec 28 07:00:35 2012 INFO
Uninstalling AAM
AAM Uninstall Status: 1 and 0
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 0 error(s), 1 warning(s)
WARNING: DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is not installed so should not be there in the deployment file
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
Exit Code: 0 - No error.
Please see specific errors and warnings for troubleshooting. For example, ERROR: DF037 ... WARNING: DW039, DW063 ...
END - Installer Session
Thank you Jeff. I happen to find the following post for CS5, which worked in this case for CS6 Dreamweaver.
http://forums.adobe.com/thread/628980
1. Click Start, right-click Computer, and select Manage.
2. Select Local Users and Groups, and open the Users list.
3. Right-click Administrator and select Properties. Uncheck Account Is Disabled and click OK.
4. Log off or Switch Users; then log on as Administrator (which now appears on the Welcome screen).
5. Disable any Anti-Virus software.
Your install log indicates you are facing file permission issues. You can see an example here:
DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\Keyfiles". Error 145 The directory is not empty.(Seq 1) [ 1904] Fri Dec 28 07:00:31 2012 WARN DW063: Command ARKDeleteDirectoryCommand failed.(Seq 1) [ 1904] Fri Dec 28 07:00:31 2012 ERROR DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc\CreativeCloud-CS6-Win-GM". Error 145 The directory is not empty.(Seq 2) [ 1904] Fri Dec 28 07:00:31 2012 WARN DW063: Command ARKDeleteDirectoryCommand failed.(Seq 2) [ 1904] Fri Dec 28 07:00:31 2012 ERROR DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc\CreativeCloud-CS6-Mac-GM". Error 145 The directory is not empty.(Seq 3) [ 1904] Fri Dec 28 07:00:31 2012 WARN DW063: Command ARKDeleteDirectoryCommand failed.(Seq 3) [ 1904] Fri Dec 28 07:00:31 2012 ERROR DF037: Unable to delete directory "C:\Program Files (x86)\Common Files\Adobe\ssc\AMT". Error 145 The directory is not empty.(Seq 4)
You will want to adjust the file permissions for C:\Program Files\Common Files\Adobe and C:\Program Files(x86)\Common Files\Adobe. You can find information on how to adjust the file permissions at Error "Exit 6" or "Exit 7" | Install log | Read, write, system file errors | CS5, CS5.5 - http://helpx.adobe.com/creative-suite/kb/error-exit-6-exit-7.html. Please make sure you apply the permission change to all child objects.
In general you can find information on how to review and interpret your installation log at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
Interesting this would indicate that either the permissions for your current user account is compromised or that your virus protection software was interferring with the install process. Thank you for the update.
