1. Re: Getting error 1316 when attempting to uninstall Elements 9
18qwer Jan 2, 2013 4:20 AM (in response to JT-in-AZ)Run the MS FixIt utiltiy, then see if you can use the Control Panel to uninstall:
http://support.microsoft.com/fixit/
If that doesn't work, here are the Adobe instructions for manually removing PSE9, you'll have to adjust for PSE10:
http://helpx.adobe.com/photoshop-elements/kb/manually-remove-photoshop -elements-9.html
2. Re: Getting error 1316 when attempting to uninstall Elements 9
JT-in-AZ Jan 2, 2013 11:02 AM (in response to 18qwer)18qwer...
Thanks for the answer, it mostly worked.
Microsoft's fixit said it corrected the problem, and it did, but left a ton of registry fragments, Adobe Active File Monitor v9 running, and a "ghost" of Photoshop Elements 9 in uninstall. I believe that anyone else viewing this can quit here and run just fine.
Wanting a cleaner system, I then went through the manual uninstall procedure. It was a bit different than documented, probably because of changes made by fixit. There were still a few fragments which I removed myself.
Elements 11 seems to be working fine. Elements 9 seems to be 99% gone. I'm happy.
Unless experienced with the registry, I would recommend most users with this problem stop after successful execution of fixit.
