I bought Adobe Acrobat X Standard upgrade from Amazon in June, 2012. I uninstalled before the hard drive failed on my computer. I installed a new hard drive, but now cannot find the CD/DVD. I have everything else (packaging, S/N, etc.)
Can you provide a download of this program or can I buy a new CD/DVD?
Larry Barton
Try http://prodesigntools.com/all-adobe-cs5-direct-download-links.html and activate it with your serial number.
Follow the Very Important Instructions on that page first otherwise the links won't work.
Mr. Waller,
Thanks for your prompt response.
I did not find Acrobat X Standard in the list you provided, only Acrobat X Pro.
Larry Barton
[signature deleted by host[
There is no separate Acrobat X Standard trial. It's included in the Acrobat X Pro trial.
The serial number unlocks either the Standard or Pro features.
Download the Acrobat X Pro trial, activate it with your serial number and it will revert to Acrobat X Standard.
My serial # does not work. I tried it with and without the dashes.
<Removed by Moderator>
Larry Barton
WLarryBarton please keep in mind this is a public forum. Please do not post personal information such as your serial number for Acrobat.
Thanks, did not realize it was public.
Do you have an answer for my problem?
Larry Barton
[private data removed]
What do you mean by serial number does not work? Is there an error message?
You mentioned in your first post that you bought an upgrade.
If that's the case, your serial number will be recognised as an upgrade by the Acrobat X installer and the installer will request that you enter the serial number from an earlier qualifying version.
Then you enter the serial number for an earlier version of Acrobat in order for for your upgrade serial number to be accepted.
Upgrade
Larry Barton
WLarryBarton wrote:
Upgrade
Refer my earlier Post #7
"If that's the case, your serial number will be recognised as an upgrade by the Acrobat X installer and the installer will request that you enter the serial number from an earlier qualifying version.
Then you enter the serial number for an earlier version of Acrobat in order for for your upgrade serial number to be accepted."
It only says the serial number is invalid.
Larry Barton
Message was edited by: Jeff A Wright to remove personal information.
This is a public forum; please do not publish your email address and other private data. I have removed your email address and telephone number from your post.
