Locked
9
How to Recover a File Accidentally Saved Over in Photoshop?
Dec 30, 2012 Dec 30, 2012
hi, I have a serious problem here... I saved a file as PSD ,then delet all the layers and was doing another stuff on the sheet( the reason I did this is because I wanted the same page size and was lazy to enter the size:| )after I finished, I saved the file to another name. but, I found that the first file that i saved manually , is replaced by an autosave file on my work procedure on the second file. I know this happend because I was working with the sama names, but is there any way that I can restore my first file that I saved to what I manually saved?:( I didnt know this whould happend... adobe shouldnt autosave on the manually saved files...:( pleaseeeeeeeeee help me, what can I do here?
macOS , Windows
232.2K
Community Beginner , Feb 19, 2015 Feb 19, 2015
Sorry to bring up an old thread but a Google search for this same problem kept bringing me here. Not sure if this is a new feature or not but I accidentally did the same thing. I opened up a file to use the layout, re-did a whole new ad and then in a hurry, two hours later I pushed the (command+s) button and to my dismay, saved over the entire original file. Then I opened up the history panel from the windows drop down and noticed at the top of the history panel there was a version of the file,
Adobe
That has nothing to do with the autorecovery files, because they're not saved in the same place as your original document.
There is no autosave in Photoshop that would save over your file.
If you have the file still open, you can save it to another filename.
If you have backup software, or version control software, you can recover it.
But in general you aren't going to recover a file you accidentally saved over.
Thanks for the reply chris, But I didn't accidentally saved over!( dunno why adobe forum changed my topic!) I saved the file first under the name" page 13" then continue working on it , after finished, I saved it under the name "page 14". but the second file was not the completion of the first one! I need both files.. but I found that photoshop changed the contents of what I saved as the page 13, to the work procedure after I saved! but I want the file goes back to what I saved manually... what should I do? ( and I disn't set any recovery backup for my Pc!:( )
Guest
If you pressed "save" it will save over the file,  if you use "save as" it will save to what you call it.  Sounds like you pressed save as that is only way PS will overwrite the file.  You can not recover from this unless you have another copy somewhere.
Sorry to bring up an old thread but a Google search for this same problem kept bringing me here. Not sure if this is a new feature or not but I accidentally did the same thing. I opened up a file to use the layout, re-did a whole new ad and then in a hurry, two hours later I pushed the (command+s) button and to my dismay, saved over the entire original file. Then I opened up the history panel from the windows drop down and noticed at the top of the history panel there was a version of the file, as it was, when I opened it. So I saved the file as a different name, crossed my fingers and pushed the little button at the top of the history actions next to the thumbnail of the original file. And BAM! it restored the file back to it's original glory it was in, right when I opened it. Re-saved the original and was able to keep both files. Yay, win for me!
Apr 07, 2015 Apr 07, 2015
Lifesaver! Thank you Kilo!
Apr 24, 2015 Apr 24, 2015
Thank you Kilo!! You just saved me from a huge headache! When I had realized my screw up I kept undoing hoping to get back to my original but it only saves so many changes and I thought I was in big trouble. But no matter what it saves the original. So good to know!
Jun 21, 2016 Jun 21, 2016
seriously lifesaver.... thanks a lot
Jul 04, 2016 Jul 04, 2016
Thank you for taking the time to post this! The exact same happened to me and I'm glad I found a way to recover.
Aug 26, 2016 Aug 26, 2016
thank you so much!
Sep 13, 2016 Sep 13, 2016
I agree with everyone else, THANK YOU!!!!
I found your response and was afraid that I had already closed it because I was so .... at myself, but it was still open and, as you said it, BAM!
There it was!!!!
Jan 23, 2018 Jan 23, 2018
thanks! THANKS
Sep 28, 2020 Sep 28, 2020
Thank you so much!
You saved me 😄
May 22, 2021 May 22, 2021
You're a hero! Thank you so much!
Jan 23, 2022 Jan 23, 2022
Saved my day ❤️ Thanks!!!!!
Feb 19, 2023 Feb 19, 2023
Hello, dear kilo the same problem got me and I cannot recover or get my work history. what version did you recover my adobe version is cs6 2016 please anyone help me I must have to submit a project today please help me to recover my work.
Jan 06, 2024 Jan 06, 2024
Thank youuuuu, you saved me some time :timer_clock:️ 🙏
Sep 10, 2015 Sep 10, 2015
You are an amazing person! thank you!
Mar 24, 2016 Mar 24, 2016
Thank you for this solution.
Oct 09, 2017 Oct 09, 2017
You actualy saved me 4 hours of work. THank you!
Aug 02, 2019 Aug 02, 2019
i closed and saved the file weeks ago with flattened layers, and have no backup method in my imac, is possible to recover the previous version?
If you have Time Machine, you can use that to go back to an earlier version. Otherwise, no.
~ Jane
May 03, 2021 May 03, 2021
Add me to the list, two years later! I was shocked to find the previously saved version. THANK YOU!
Sep 19, 2021 Sep 19, 2021
This might help someone.
I recently saved over a Photoshop .psd file by mistake but was able to recover it in Windows 10, even after closing it. I opened windows file manager and navigated to where the file was saved. Then right clicked on the new saved version and selected "Version history". I picked a version from before I had saved over it. Then, I clicked on the three vertical dots to the right and selected the "Restore" option.
Kilo's solution didn't work for me, as the only things shown were changes I had made to document.
Should also mention that while doing the above I had the new version of the file open in Photoshop. And once I did the recovery of the overwritten version, I changed the file name in Windows file manager. Then went back to Photoshop and resaved the open new version.
