1 Reply Latest reply: Dec 31, 2012 2:14 PM by nic_tunney RSS
    Getting an Error with EventGateway in Mac OSX 10.8
    nic_tunney CommunityMVP
      Two machines, both fresh ColdFusion installs.  Set up a Gateway Instance named cfflexgw.  Point it to a working CFC and the local cfg file.  When I send a simple message to the gateway, I get the following error:
      Unable to find the Flex adapter for destination ColdFusionGateway in the RMI registry on localhost:1099.
      Multiserver 9.0.2.  Using the base cfusion instance, and I did not alter any of the xml config files yet.  This code worked on 9.0.1 (and is still working) in OSX 10.7.  I also tried a stripped down CFC and message.  Any help yoiu can provide is appreciated!  Remoting is working fine BTW, just not sending message from CF via the ColdFusionGateway.
      Nic
