1 2 Previous Next 58 Replies Latest reply on Aug 20, 2016 4:23 AM by justing42831840
    Photoshop CS6 does not open or create files
    hoochblues Level 1
      I am using Adobe Cloud. And have downloaded Photoshop CS6. Using it locally.
      It was working fine.  For weeks. The application still loads without error. But if I open a file nothing happens. No error message. But no file appears. And if I try to create a new file the same thing. No error message. But no new canvas to work with. In both cases nothing appears in the layers panel.
      The Help menu gives me the option of deactivating. So I am assuming it is not an activation issue.
      Fireworks works fine. Illustrator works fine. Only Photoshop has this problem.
      I am running Windows 8. 64bit. 12gb. NVIDIA GeForce GTX 560 2gb. Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64. No optional 3rd party plugins.
        • 1. Re: Photoshop CS6 does not open or create files
          c.pfaffenbichler Level 9
          Boilerplate-text:
          Are Photoshop and OS fully updated and have you performed the usual trouble-shooting routines (trashing prefs by keeping command-alt-shift/ctrl-alt-shift pressed while starting Photoshop after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed, 3rd party plug-ins deactivation, system maintenance, cleaning caches, font validation, etc.)?
          • 2. Re: Photoshop CS6 does not open or create files
            hoochblues Level 1
            Photoshop up to date - Yes
            Windows 8 up to date - Yes
            Cleared prefs - Already tried
            Uninstalled. Re-installed. Now it works.
            • 3. Re: Photoshop CS6 does not open or create files
              cykopat Level 1
              I just started having the same issue just last week. I open photoshop with or without 3rd Party plugins and I can't:
              • Create a New File
              • Open any existing file
              No idea, what the cause of this is. Everything is up to date.
              System Specs: Asus Rampage IV Extreme, i7-3930K, 64GB PC-2400 DDR3, Intel 520 Series SSD, RevoDrive 3 X2 Adobe Drive and a few other SSD's. Running windows 7 x64.
              • 4. Re: Photoshop CS6 does not open or create files
                hoochblues Level 1
                The only thing that fixed this for me was a reinstall. I am sure there is an easier way. But I wasn't able to find it.
                1 person found this helpful
                • 5. Re: Photoshop CS6 does not open or create files
                  cykopat Level 1
                  I still can't open or create new files after I use Photoshop once.
                  Reproduction:
                  1. Restart Computrer
                  2. Open Photoshop (functions normal)
                  3. Close Photoshop
                  4. Re-Open (No Longer can Create or Open Files. However you can open bridge and drag and drop the file into PS and it will display it's just uneditable)
                  5. Restart Computer
                  6. Cycle Repeats
                  Graphics Card: EVGA GTX680 4GB
                  Driver Version: 314.07
                  Windows 7, x64
                  64GB DDR3 PC-2400 MEMORY
                  i7 3930K 4.2Ghz
                  Attached System Info Files
                  Adobe Sys Info
                  https://creative.adobe.com/share/6c62023e-4180-4f6a-b9a1-fe92050b7fec
                  Nvidia SYS Info
                  https://creative.adobe.com/share/660d285f-eaf0-4db6-a456-5a62171f9536
                  • 6. Re: Photoshop CS6 does not open or create files
                    Curt Y Level 7
                    Have you tried resetting preferences?  Start PS and immediately hold down Ctrl alt shift keys.  If fast enough you will get a reset window.
                    • 7. Re: Photoshop CS6 does not open or create files
                      cykopat Level 1
                      Yep.. Just did a complete re-install. Same thing open PS6 after a reboot and everything works fine. Close PS6 and Re-Open it and Can't Create New Files or Open Files.
                      • 8. Re: Photoshop CS6 does not open or create files
                        Curt Y Level 7
                        A re-install will not affect the preferences file.  If there was corruption in the file before it will still be there after re-install.
                        • 9. Re: Photoshop CS6 does not open or create files
                          cykopat Level 1
                          I'm sorry I should have been more clear the preference cleanup/reset I tried the very first time. I notice it started after the last PS6 update. So last night I did the following.
                          • Uninstall Creative Cloud
                          • Ran Creative Cloud Cleaner
                          • Deleted all preference files in \users\documents\X\appdata
                          • Re-installed to another drive in the system (Creative Suite)
                          Like clockwork I can open Photoshop without a problem the first time. If I close PS6 and re-open it I am unable to Create a New File, Open any existing graphics or PS compatible files until I reboot again. Hitting CTRL-N shows me the new file dialogue which I can't get to show up from choosing File-->New. However, once I hit enter on the dialogue it goes away but no ned file is opened.
                          I can also drag images into photoshop via bridge and they show up. However, they are uneditable I can't make new layers and I can't edit the file. It's like I see it in PS6 but PS6 dosesn't know it's there.
                          • 10. Re: Photoshop CS6 does not open or create files
                            cykopat Level 1
                            Update 03/2/2013
                            I had enough I uninstalled Creative Cloud and secure wiped the Intel 520 SSD and the wiped the RevoDrive 3 X2. Installed windows 8 clean install and re-downloaded and installed all the Creative Cloud Apps.
                            1. After the install was completed clicking on Photoshop CS6* causes nothing to happen. No tasks open, nothing in task manager showing photoshop opening. It's like the request just goes away.
                            2. Figured maybe I need the updates, opened bridge clicked on help - updates.
                            3. All products had updates and updated them all.
                            4. All updates successful except for Photoshop and DynamicLinkmanager.
                            Photoshop Update Failed
                            Adobe Photoshop 13.0.1.1
                            Installation failed. Error Code: U44M2P7
                            So then I search the forums and find the option to manually download the CS6 update from Adobe.com. I did that and still nothing.
                            So in Windows 7 I could open Photoshop once per reboot and work. Now in Windows 8 I can't even get it to open.
                            There has to be an incompatibility with either:
                            1. Nvidia GTX680 4GB cards
                            2. Nvidia WHQL Latest Drivers
                            I draw that conclusion because PS CS6 has worked just fine until Nvidia Updates were installed. I know in 3D Mark III the card only reports as a 2GB and they claim it's purely cosmetic reporting. It also works fine on my Quadro 5000 card in another box.
                            1. Unable to open Photoshop CS6 in Windows 8 Pro
                            2. Unable to open using program Compatibility Troubleshooter Mode: Windows 7
                            3. Unable to open images in Adobe Camera Raw or Photoshop from within Bridge. No Errors it's like the request simply disappeared.
                            sniffer_GPU Report:
                            Device: 0000000000312F28 has video RAM(MB): 1868
                            Device: 00000000002FBB88 has video RAM(MB): 4095
                            Vendor string:    NVIDIA Corporation
                            Renderer string:  GeForce GTX 680/PCIe/SSE2
                            Version string:   3.0.0
                            OpenGL version as determined by Extensionator...
                            OpenGL Version 3.0
                            Has NPOT support: TRUE
                            Has Framebuffer Object Extension support: TRUE
                            OpenGL ok
                            OpenCL ok, version=1.1 CUDA 4.2.1
                            Return code: 3
                            PS6 Executable Digital Signature:
                            sha1 - Monday, January 7, 2013 12:36:15 PM
                            System Info From Lightroom (Since PS6 doesn't open)
                            Operating system:  (Build 9200)
                            Version: 6.2 [9200]
                            Application architecture: x64
                            System architecture: x64
                            Logical processor count: 12
                            Processor speed: 3.2 GHz
                            Built-in memory: 65476.6 MB
                            Real memory available to Lightroom: 65476.6 MB
                            Real memory used by Lightroom: 159.9 MB (0.2%)
                            Virtual memory used by Lightroom: 123.0 MB
                            Memory cache size: 0.0 MB
                            Maximum thread count used by Camera Raw: 6
                            System DPI setting: 96 DPI
                            Desktop composition enabled: Yes
                            Displays: 1) 1920x1080, 2) 1920x1080
                            System Hardware Specs:
                            • OS Drive (Intel 520 240GB SSD)
                            • Motherboard: Asus Rampage IV Extreme x79 Chipset
                            • CPU: Intel i7 3930K
                            • Memory: 64GB PC-2400 G.Skill
                            • Adobe Creative Cloud is installed on the D:\ Drive which is an OCZ Revodrive 3 X2.
                            • Video: EVGA GTX680 Classified 4GB Edition
                            • Video Drivers: Nvidia 314.07, DirectX 11.0, API Version 11.1, Clock 1110Mhz
                            *Photoshop CS6 refers to both the x64 edition and 32bit edition. I've tried both.
                            • 11. Re: Photoshop CS6 does not open or create files
                              cykopat Level 1
                              So frustrating..Here's hoping an update fixes this. It sucks to reboot or leave photoshop open 24-7 in order to use it.
                              • 12. Re: Photoshop CS6 does not open or create files
                                dodgepong Level 1
                                I, too, have an EGA 680 4GB (FTW Edition) and have been having this same issue. Photoshop will not open files or create new files after being open for a while after restarting it. Is this something Adobe has to fix, or nVidia?
                                • 13. Re: Photoshop CS6 does not open or create files
                                  Sheldon Pacotti Level 1
                                  Same problem with latest update as of July 1.  I wonder if it's an account/permissions malfunction.  Other apps don't have this problem.
                                  I'd be happy to provide more info if someone at Adobe would like to look into this.
                                  • 14. Re: Photoshop CS6 does not open or create files
                                    More info:
                                    I don't experience this problem under the Administrator account on the system.  I can open and close Photoshop all I want and create new files.
                                    Under a secondary account without Adminstrator privileges, I can't seem to get rid of the problem even after killing all Adobe Cloud processes and re-running everything as Administrator.
                                    • 15. Re: Photoshop CS6 does not open or create files
                                      Curt Y Level 7
                                      This means you have a permission problem in the OS.  You are not authorized to read/write to disk or folders.
                                      • 16. Re: Photoshop CS6 does not open or create files
                                        CAR141 Level 1
                                        @Sheldon Pacotti - I'm having the same problem you describe. Was the problem resolved by running Photoshop CS6 as Administrator?
                                        • 17. Re: Photoshop CS6 does not open or create files
                                          Sundig Level 1
                                          I have the same type of problem.  The only way Photoshop CS6 will open a file is to completely shut down.  When it opens up again it will only open one file,and then it goes back to the same problem.  It also will not create a new canvas.  When Iwas able to open the one file I tried using the brush tool.and it would just partially work.  Just for the hell of it i switched my mouse and believe it or not everything went back to normal.  The old mouse would work great in everything else such as Premiere etc. but not in photoshop.  It was not a bettery problem in the mouse as they were new batteries, just something wrong with the mouse.  I sincerely hope this works for everyone who is having this problem, as it was sooooo frustating.  Let me know.
                                          Carliosis
                                          • 18. Re: Photoshop CS6 does not open or create files
                                            CAR141 Level 1
                                            My original post here was july 12, 2013.  I have found that there doesn't seem to be any one fix to this problem. I thought I'd add this post since my Photoshop now works although I cannot tell exactly what fixed it.
                                            My computer is a PC.  My problem started right after I updated CS6. I could open Photoshop (CS6), open one file, maybe be able to work on it (or not). If I could work on it if would find when I tried to open another photo file it would not open at all. I could reboot and again open one file in Photoshop. I described the problem on several forums and received nothing that helped. I tried virtually everything suggested above in this post and from other forums. All drivers were up to date. Lack of memory was not the problem. Most solutions did not work or only worked for a short while and then the problem would return. I did replace the mouse and it didn't help. I even completely reloaded Windows 7 and all my software, one thing at a time, and Photoshop worked for three days and then, having made no further changes in the computer by adding any software, etc. during those three days it again went to opening no files or opening only one and refusing to open any more until after rebooting the computer.
                                            I contacted ADOBE again (their original suggestions had not worked) and they suggested opening msconfig, disabling all in the Startup Tab and then going to Services, clicking the Hide all Microsoft services, and then disabling all. After doing this Photoshop began to work normally which was weird because I had already tried this and it hadn't helped. This time it worked so something else must have changed somewhere. I have gradually added needed files (anti-virus, anti-malware, Google, Adobe, etc.updaters, monitor calibration software, all my Photoshop and lightroom plug-ins, Microsoft Office, etc.) and my Photoshop CS6 is still working.
                                            • 19. Re: Photoshop CS6 does not open or create files
                                              MaxCalo Level 1
                                              Thanks for the advice. I'm having the same problem.
                                              I'm also running Windows 7 64 and I have PS 5.5 and PS CC (one I own outright the other on subscription) and they both suffer the same problem.
                                              They worked again after I did what you suggested in msconfig.
                                              I now keep everyting disabled apart from the Microsoft, Adobe and Wacom items. Still, occasionally PS is unresponsive and I have to reboot.
                                              • 20. Re: Photoshop CS6 does not open or create files
                                                DaniVince Level 1
                                                I've been having the same problem.  I tried everything on this thread.  The reason the MSConfig tweak works is because the problem is with your permissions - the tweak is turning off services, one of which may be affecting your permissions.  To restore your permissions, open a command prompt and type
                                                secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose
                                                this should solve any permission problems.
                                                • 21. Re: Photoshop CS6 does not open or create files
                                                  liefeng Level 1
                                                  Same problem here. Premiere, AE, PS cs6 don't have canvas, but AI is ok. My laptop has two graphics cards, intel hd4000 and nvidia 650m. Disable intel graphics card and problems solved. Hope this help.
                                                  • 22. Re: Photoshop CS6 does not open or create files
                                                    You may want to try and update your GPU driver.
                                                    • 23. Re: Photoshop CS6 does not open or create files
                                                      cykopat Level 1
                                                      Done this, tried this. Evenafter rebooting and with PhotoShop open about 20 minutes later unable to open any new files or create new files. Can save existing files.
                                                      • 24. Re: Photoshop CS6 does not open or create files
                                                        PECourtejoie Adobe Community Professional
                                                        On which disks are the programs, users-preferences folder, etc. located? The permissions should be ok, since you did a reinstall... but did you check the ones on your other disks?
                                                        Can everyone affected share Photoshop's help>system info?
                                                        • 25. Re: Photoshop CS6 does not open or create files
                                                          MaxCalo Level 1
                                                          I solved my problem, at the end the problem was the antivirus (avast). I uninstalled it and it's been perfect since.
                                                          • 26. Re: Photoshop CS6 does not open or create files
                                                            RotaryAce1 Level 1
                                                            I'm having the same issue - have tried all of the sugestions here and nothing seems to be working. Photoshop wil only load or create new files if opened immediately after start.
                                                            • 27. Re: Photoshop CS6 does not open or create files
                                                              devon-m Level 1
                                                              I have tried every "solution" in this thread and nothing works. I have also done a lot of troubleshooting myself and nothing.
                                                              I have noticed something that I haven't seen in these threads. If you spam Ctrl+N the dialog window will eventually pop out, however clicking ok does not create a new file. It just goes away. If I spam Ctrl+N and spam click left mouse button where the OK button is once the dialong window pops up, it will eventually create a new file. However it seems to refresh every second or two. If I were to hold down left mouse and draw with my brush tool, I can only draw for maybe 1 second, then it stops drawing. If I then release left mouse the line that I drew goes away. I can however draw small lines before it refreshes, if I tap click my left mouse.
                                                              I'm worried that what I wrote might be difficult to understand. If requested, I will make a video.
                                                              Thanks.
                                                              • 28. Re: Photoshop CS6 does not open or create files
        Level 5
        devon-m wrote:
        …If you spam Ctrl+N…If I spam Ctrl+N and spam click left mouse button…
        Would you care to explain your use of the word "spam" in this context?  Thank you.
        • 29. Re: Photoshop CS6 does not open or create files
        devon-m Level 1
        Pressing the key or key combination repeatedly. By pressing Ctrl+N several times quickly, I can get the new file dialog box to appear after 3 to 4 quick presses of the key combination. Pressing the key combination slowly does not work. You have to tap Ctrl+N rapidly.
        • 30. Re: Photoshop CS6 does not open or create files
        Adibahasan Level 1
        i just made pretty much the same post, http://forums.adobe.com/thread/1426275
        this is a big problem and i don't like restarting my computer every time.
        • 31. Re: Photoshop CS6 does not open or create files
        CAR141 Level 1
        Have you tried directly contacting Adobe for help with this problem? I also had this problem, went through all  suggestions on this thread and nothing helped. I contacted Adobe and within a few minutes had a solution. I know the problem is that you try a solution and then have to go back and use Photoshop to see if it helped and often it doesn't.
        Here is what worked for me which doesn't mean it will work for you. MY Os iw windows 7 and I have Photoshop CS6.
        I contacted ADOBE again (their original suggestions had not worked) and they suggested opening msconfig, (type in "search programs and files" box that opens when you click the Start button in bottom left corner of screen. Then disabling all in the Startup Tab and then going to Services, clicking the Hide all Microsoft services, and then disabling all. After doing this Photoshop began to work normally which was weird because I had already tried this and it hadn't helped. This time it worked so something else must have changed somewhere. I have gradually added needed files (anti-virus, anti-malware, Google, Adobe, etc.updaters, monitor calibration software, all my Photoshop and lightroom plug-ins, Microsoft Office, etc.) and my Photoshop CS6 is still working.
        • 32. Re: Photoshop CS6 does not open or create files
        devon-m Level 1
        I have indeed tried this and no luck. I had nothing startup and no services (aside from microsoft ones, of course) and I thought it fixed it. Until about 3 hours later, then Photoshop did the exact same thing again.
        • 33. Re: Photoshop CS6 does not open or create files
        DK_ Level 1
        I have the same issue and the last thing I did was update my NVIDIA drivers.  I am removing the lastest driver to see if this fixes it.
        *UPDATE* after removing the current NVIDIA driver, and installing an older version all PS C6 issues as described by everyone above has gone away.
        Hope this helps
        • 34. Re: Photoshop CS6 does not open or create files
        devon-m Level 1
        I wish that fixed it for me, but it has not.
        I have tried almost everything to fix this, but no luck. I'm about to go as far as building a new computer. I'm so fed up with this. Contacting Adobe is useless and several threads on this forum are still unsolved.
        Does Photoshop have some sort of debug mode? If I could find a way to log EVERYTHING that it's doing, that would be a huge help.
        • 35. Re: Photoshop CS6 does not open or create files
        Level 7
        So far everytime we've heard about something like this, the culprit has been malware, a corrupt OS install, or something else outside of Photoshop.
        There isn't much Adobe can do about this issue on your system.
        • 36. Re: Photoshop CS6 does not open or create files
        cykopat Level 1
        This would happen on a clean install of Windows 7 and Windows 8. I started noticing it when I went to 7 series Nvidia Cards.
        • 37. Re: Photoshop CS6 does not open or create files
        devon-m Level 1
        It's likely a hardware issue, Chris. I switched from Windows 7 to Vista and the problem persisted, so I switched back to 7. Photoshop was one of the first programs installed when I switched, it was even installed before many drivers. It's quite obvious that it's something else outside of Photoshop, but why is Photoshop the only program affected by this? It's also incredibly odd that the solutions vary. Some have fixed it by updating their graphics drivers, rolling back their graphics drivers, resetting windows permissions, getting a new mouse and/or keyboard, making a new user account, so on and so forth. I have tried all of those and then some. It's also strange that the problem occurs after a random amount of uptime. Sometimes it's breaks 5 minutes after booting and sometimes it's 3 hours. It's such a strange issue that I have never encountered before with any other computer or program.
        • 38. Re: Photoshop CS6 does not open or create files
        Level 7
        If the problem goes away after rebooting, but not when restarting the app - as has been repeated here many times - then the problem must exist outside of Photoshop.
        And the people who've solved it have done so by removing other software, or reinstalling their OS.
        • 39. Re: Photoshop CS6 does not open or create files
        DK_ Level 1
        Try re-installing Adobe Flash, reverting to an older video driver and/or doing a roll back with windows 7.  This is not an hardware issue, it is a software issue.  I do technical support and every solve for this issue has been one of the above three that I posted.
        you do not need to reinstall windows to make this work.
        1 2 Previous Next
