5 Replies Latest reply: Jan 1, 2013 10:01 PM by juskocf RSS
    AME says Disk is Full
    juskocf Community Member
      Using Premiere Pro CS6 to export 1080p50 with export setting "Match sequence settings", AME always pops up a window saying error compiling movie, disk is full.
      Is there a solution to the bug yet ?
      Regards
        • 1. Re: AME says Disk is Full
          JSS1138 CommunityMVP
          How is the hard drive formatted?
          • 2. Re: AME says Disk is Full
            jwwebb
            I am having the same issue except my format is 1080p60.  My hard drive is formatted as NTFS file system and I have a 64 bit machine with Windows 7.  I am using a AVCHD video camera and have made color corrections in Premiere Pro CS6.  I want to keep the 1920 x 1080P with 59.97 fps configurations and store on my hard drive.  I get the mpeg format as the selection (the original file format is .m2ts) and I can make no changes to that selection, but, like mentioned above, after 20-30 seconds of AME processing I receive a disk full error even though I have well over 1.1 TB file space free and the original clip was about 82 MB in size.
            • 3. Re: AME says Disk is Full
              Does this occur only with the oddball 1080p/60 (or 50) exports, or does other media also have problems?
              • 4. Re: AME says Disk is Full
                jwwebb Community Member
                I have only tried the 1080p/60 format, but can try another format as well.  I am sharing another forum entry link from another person where the same problem appeared to be happening as well and they seemed to try other options and still had issues and it looked like the issues was being explored by the technical team but I saw no resolution.  Thought this might help.  Here is the link - http://forums.adobe.com/message/4630703
                • 5. Re: AME says Disk is Full
                  Just tried the 1080i 25fps (50i) without problem.
                  It seems the problem only occurs with the 1080p50/60 .
                  Regards
