Loop in a CFC
Dec 27, 2006 Dec 27, 2006
am trying to write a query in a Function where i need to return results for a search criteria from a form.
search has 3 drop down lists which has 3 text boxes assigned to retrieve results based on the selection and entering text.
let's say first drop down has a list value of "Customer name" and search value is "John" ..
Query has to retrieve. results where " Customer name" is "John"
like wise i've 3 Dropdown boxes .. which has same list values (i.e., customer name, customer city, country etc.,)
and 3 text boxes, and 2 Operator boxes ("and", "Or) .
Pls.see the Screen Shot here
and i want to retrieve results by looping those 3 list boxes in my Query and sametime using the textbox values and operator.
CFFUCNTION doesn't allow type "struct" in arguments if the return type is "query"
here is the code
<cffunction name="getList" output="true" returntype="query" >
<cfargument name="searchstring" type="any" required="no" default="">
<cfargument name="searchvalue" type="any" required="no" default="">
<cfargument name="operator" type="any" required="no" default="">
<cfquery name="get_values" datasource="#application.dsn#">
SELECT * FROM TABLE
WHERE 0=0
AND
<CFLOOP INDEX="i" list="#arguments.searchstring# delimiters=",">
-- here i need to get the corresponding "textbox" and "Operator" values --
for ex: AND (operator) CUSTOMER_NAME LIKE %JOHN% (textbox value)
</cfloop>
</cfquery>
</cffunction>
Thanks in advance
Weblover.
Advanced techniques
660
New Here , Dec 29, 2006 Dec 29, 2006
Hi BKBK,
thanks a bunch for your help.. it worked.... i just replaced my code with yours with little modifications..and works perfect..
thanks again.
Weblover.
It might be simpler to get your query working in a normal template before adding the complication of a cfc. Try to simplify as much as you can. Your post leads me to believe you are overthinking your problem.
Participant ,
Don't know if it means anything, but you forgot to terminate your list attribute with a quotation mark. Also, is arguments.searchstring a list, or a struct? If it's a struct then it belongs in the collection attribute instead of list, and requires the item attribute instead of index.
I hope this points you in the right direction
Hi BKBK,
thanks again.
Weblover.
Documentation
