This question was posted in response to the following article: http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7fa9.html
IsQuery will return true even if there are zero records in the record count.
Yes, all IsQuery does is check to see if the object is a query, or not (boolean). Even if there are no records returned, a query is still a query.
If you want to check to see if a query has more than 0 records in it, use <cfif queryName.recordCount gt 0></cfif>
^_^
It is not the records which make a query a query. It is the two-dimenstional structure which ColdFusion creates to hold the records. To compare, an empty HTML table is still a a table.
Use the test:
if isQuery(myQuery) and myQuery.recordcount gt 0
