I have successfully download and installed CF10. Admin tools comes up and seem to work with all needed connections (email and Data sources to be specific). However, I cannot run my current site without CF9 being up and running? Did I miss a configuration? DOes CF10 need to know where my code is and NOT IIS? Where can I get Technical help to debug? ...Help..
The CF forum is your friend. It's much more likely you will get answers there...
Mylenium
Moving this discussion to the Cold Fusion forum.
If you want ColdFusion 10 to run your site on IIS, then you should run the Web Server Configuration Tool and add IIS. The tool is: C:\ColdFusion10\cfusion\runtime\bin\wsconfig.exe
