1. Re: Repoussé on Photoshop CS5 Extended Won't Work
c.pfaffenbichler Aug 1, 2010 11:54 PM (in response to Webkinzhodder)Photoshop – Preferences – Performance
There is a field titled GPU Settings, therein check Enable OpenGL Drawing.
2. Re: Repoussé on Photoshop CS5 Extended Won't Work
Webkinzhodder Aug 2, 2010 8:10 AM (in response to Webkinzhodder) -
3. Re: Repoussé on Photoshop CS5 Extended Won't Work
c.pfaffenbichler Aug 2, 2010 8:22 AM (in response to Webkinzhodder)1 person found this helpfulThat, I’m afraid, might indicate that your graphic card does not support OpenGL.
Check for your card on this list:
4. Re: Repoussé on Photoshop CS5 Extended Won't Work
Webkinzhodder Aug 2, 2010 8:35 AM (in response to Webkinzhodder)It's not there, so I guess I can't use 3D. Thanks!!!
5. Re: Repoussé on Photoshop CS5 Extended Won't Work
c.pfaffenbichler Aug 2, 2010 8:44 AM (in response to Webkinzhodder)You should still be able to use some of the 3D-features, like 3D – New Shape From Layer, to create simpler forms like cubes and cones or Place 3D-models, but to use Repoussé you might have to invest in a new video card.
6. Re: Repoussé on Photoshop CS5 Extended Won't Work
Alex_Reds Nov 17, 2010 12:18 PM (in response to c.pfaffenbichler) -
7. Re: Repoussé on Photoshop CS5 Extended Won't Work
SG...Nov 18, 2010 10:44 PM (in response to Alex_Reds)
Hi Alex,
Have you tried creating a Shape layer or Text layer first, then seeing if Repoussé is active?
regards,
steve
8. Re: Repoussé on Photoshop CS5 Extended Won't Work
waynemor Dec 10, 2011 6:55 PM (in response to Webkinzhodder)It may have nothing to do with open GL at all. I was jsut having the same problem and I solved it by switching form CMYK back to RGB.
Problem solved - 3D works perfectly again
9. Re: Repoussé on Photoshop CS5 Extended Won't Work
Alex_Reds Jan 28, 2012 3:02 AM (in response to SG...)Hi Steve,
Thanks for the reply, and sorry for the delay in one year with the answer )
Now it seems sorted, I created a shape, rasterized it and Repousse seems is active. I can see all 3D modeliing tools.
Rehards
Alex
10. Re: Repoussé on Photoshop CS5 Extended Won't Work
NaMasteY GR Jan 5, 2013 4:38 PM (in response to c.pfaffenbichler)I need a quick help over here ..i have Adobe Photoshop CS5.1 Extended,,and i have 3D tab at top ..but when i (ex.) type something with Type tool...and i do all steps that i want to create 3D text..and when i click on 3D tab..and all options are GRAY ..and i canno't use response ...or any other options..and in prefrences OpenGL is enabled .and everything is Ok..and my video card is ATI Radeon HD 4300/4500 ..and when i go to upgrade my card it says that video card is up to-date ...if someone know maybe to help me or something..i will be very happy .THANKS FORWARD!!
11. Re: Repoussé on Photoshop CS5 Extended Won't Work
kim03adiran Apr 1, 2013 12:09 AM (in response to c.pfaffenbichler)Where can i found the preferences?
12. Re: Repoussé on Photoshop CS5 Extended Won't Work
vinothinin64469330 Jan 26, 2015 10:09 PM (in response to kim03adiran)edit-preference-performance
13. Re: Repoussé on Photoshop CS5 Extended Won't Work
whayelb5720084 Aug 28, 2016 8:48 AM (in response to Alex_Reds)how can the shapes i created be rasterized?
14. Re: Repoussé on Photoshop CS5 Extended Won't Work
c.pfaffenbichler Aug 28, 2016 9:04 AM (in response to whayelb5720084)Could you please post a screenshot with the pertinent Panels (Layers, Paths, Options Bar, …) visible?
15. Re: Repoussé on Photoshop CS5 Extended Won't Work
SG...Aug 28, 2016 12:28 PM (in response to whayelb5720084)
1 person found this helpfulHi,
In newer version the menu command is here (I suspect it is the same for Ps CS5, too):
regards,
steve
