I have issue installing CS Extension Builder 2.0 trial with FB 4.7 trial
The FB got installed in french though, so I'll try to translate the FB menu as much as I can.
- Download CS Extension Builder 2.0
- Unzip it in D: drive
- open FB
- Help
- Install new software
- Add
- Name : Extension Builder
- Location -> click on local browse to the folder
- FB set the path as file:/D:/CSExtensionBuilder_2_Trial_LS1/
then I select "Extension Buidler" (site) in the dropdown menu. A red cross before the dropdown appear and says "path must be absolute". It doesn't find anything to install.
I don't know what I'm doing wrong.
cheers
F.
I found the solution.
type the path directly in the dropdown menu as file:/D:/CSExtensionBuilder_2_Trial_LS1/ solved it.
