Hello,
I was wondering if it is possible on a search Result page to do something like the following
"Your Search for "<Search term>" has returned <X number> Results"
In addition, Is it possible to edit the "No result found" text ? if so where will I find this ?
Thanks you in advance.
-Chad
Hi Chad
Could you please let me know what type of search you are referring to?
(webapp, products, site-wide)
Site-wide
Sent from my iPhone
Hi Chad,
I checked for all types of search and currently your requests cannot be accommodated via BC tools. For the 2nd one there are easy work-arounds, here's an example:
http://practicallyinspired.com/_blog/Blog/post/Replace_No_items_found_with_an_your_own_HTML_layout/
For the first one however, it can get trickier, as results can be split up in pages, so you might end up writing a java script that works with ajax for loading the last page of results in a hidden div and checking the {counter} tag value, wich would represent the number of results outputted.
