I'm trying to download Adobe Flash Player (11.5) for mac OS X (10.6) and when i should get the window to check box and instal- it disappears!!!with only the top of the window (title bar) left so i can close or minimize only
I actually just learned that unless you delete your adobe.com cookie, you'll still get the online version of the installer that is causing you the problem. Here's a direct link that you can use instead:
http://fpdownload.macromedia.com/get/flashplayer/pdc/11.5.502.146/install_flash_player_osx.dmg
Chris
Does this happen when you are downloading or installing? If downloading, I'm not sure which checkbox you are referring to. Any chance you could post a screenshot?
This happens when i am installing (i have already done all the steps of the window you see behind on the screen shot: http://get2.adobe.com/flashplayer/download/?installer=Flash_Player_11_for_Mac_OS_X_10.6_-_10.8&os=OS...). I took two screen shots: one right before and one after the content has disappeared. Thanks
On that first screen shot the bar loads entirely before getting that second screen shot.
Thank you for posting these! I'm talking with our installer team and will get back to you asap.
Chris
Ok, just heard back that this is a known issue that we're working on with a new version of our installer. You should be able to install using the stand alone installer that you can download here:
I apologize for the inconvenience.
Chris
I don't understand.This link is the exact same link that i've been using to try and instal flash player.So i still have the same problem.....
What is the "stand alone installer" you are talking of?
Chris
It worked!!!! Thank you so so much!!!!
