I need to make a secure SOAP request with Coldfusion , and I'm having trouble implementing the headers properly so the service can use it.
There are two structure examples I was given
Example 1:
This is a sample soap request:
POST /WebService/EmployerWebServiceV24.asmx HTTP/1.1
Host: stage.e-verify.uscis.gov
Content-Type: text/xml; charset=utf-8
Content-Length: length
SOAPAction: "https://www.vis-dhs.com/EmployerWebService/EmpCpsVerifyConnection"
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
<soap:Body>
<EmpCpsVerifyConnection xmlns="https://www.vis-dhs.com/EmployerWebService/" />
</soap:Body>
</soap:Envelope>
Example 2:
An example SOAP authentication HEADER would look something like:
<soap:Header>
<wsse:Security soap:mustUnderstand="1">
<wsse:UsernameToken namespaces>
<wsse:Username>username</wsse:Username>
<wsse:Password Type="type info">password</wsse:Password>
<wsse:Nonce>nonce</wsse:Nonce>
<wsu:Created>date created</wsu:Created>
</wsse:UsernameToken>
<wsse:Security>
</soap:Header>
<soap:Body>
<WebServiceMethodName xmlns="Web Service Namespace" />
</soap:Body>
</soap:Envelope>
Important:
I was able to create a successful connection to this web service without including header information.
To use other functions I need a properly working header which works.
This is my code for the successful connection without the headers. (So you can reproduce it)
<cfsavecontent variable="request_xml">
<cfoutput>
<soap:Body>
</soap:Body>
</soap:Envelope>
</cfoutput>
</cfsavecontent>
<!--- Make Request --->
<cfhttp url="https://stage.e-verify.uscis.gov/WebService/EmployerWebServiceV24.asmx?wsdl" method="post" result="httpResponse">
<cfhttpparam type="header" name="SOAPAction" value="https://www.vis-dhs.com/EmployerWebService/EmpCpsVerifyConnection" />
<cfhttpparam type="header" name="accept-encoding" value="no-compression" />
<cfhttpparam type="body" value="#trim(request_xml)#" />
</cfhttp>
<!--- Show Response --->
<cfdump var="#httpResponse#" label="httpResponse">
<cfdump var="#xmlParse( httpResponse.fileContent )#" label="soapResponse">
PROBLEM:
When I insert my header into the request, then it throws me an error saying "code:InvalidSecurityToken"
(Replace cfsavecontent with this)
<!--- Define Nonce --->
<cfscript>
strNonce = ToBase64(createUUID());
</cfscript>
<cfoutput>
<soap:Header>
<wsse:Security soap:mustUnderstand="1" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
<wsse:UsernameToken wsu:Id="UsernameToken-1" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">
<wsse:Username>myUsername</wsse:Username>
<wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0##PasswordText">myPassword</wsse:Password>
<wsse:Nonce>#strNonce#</wsse:Nonce>
<wsu:Created>#Dateformat(Now(),'yyyy-mm-ddThh:mm:ss')#Z</wsu:Created>
</wsse:Security>
</soap:Header>
<soap:Body>
</soap:Body>
</soap:Envelope>
</cfoutput>
</cfsavecontent>
OTHER SOLUTIONS I HAVE TRIED:
I have tried to use createObject + AddSOAPRequestHeader + cfinvoke but nothing seems to work for me
WHAT I NEED
I need some ideas on how to get that secure header working using a cfhttp method.
After 8 hours of researching I have found nothing.
<cfscript>
</cfscript>
<cfoutput>
<soap:Body>
</soap:Body>
</soap:Envelope>
</cfoutput>
</cfsavecontent>
<cfsavecontent variable="header_xml">
<cfoutput>
<soap:Header>
</wsse:Security>
</soap:Header>
</cfoutput>
</cfsavecontent>
<cfhttpparam type="header" name="security" value="#header_xml#"/>
</cfhttp>
