Show 2 replies
1. Re: When importing an AE comp into Premiere, why does motion blur opacity have weird colored outlines?
Dave LaRonde Jan 10, 2013 1:34 PM (in response to hirethestache)Render out an alpha-channeld movie in AE and use it in Premiere? You have two choices of the type you need: Straight or Premultiplied.
It's motion-blurred, which means the motion is fast, which means it doesn't last very long, which means it isn't that big a deal in my mind.
2. Re: When importing an AE comp into Premiere, why does motion blur opacity have weird colored outlines?
Mylenium Jan 10, 2013 7:05 PM (in response to hirethestache)Editing programs favor straight Alpha, though if you use DynamicLink none of that should matter and the render use the correct native transparency in the comp. In your case it looks more liek you have a layer style applied and since they render after everything else, they do not behave correctly with motionblur. Substitute your drop shadow/ outer glow with teh respectivce normal AE effect and those issues won't appear.
Mylenium
