1. Re: Alternative to "Post Result" popup with Internal Server
Jim Leichliter Jan 11, 2013 7:41 AM (in response to OpenPegasus)If all you're traking is some basic quiz data and student info... you can use this free widget to send those variables to your server side script:
http://captivatedev.com/2012/09/17/adobe-captivate-6-x-free-widget-button-url-with-variabl es/
Unfortunately, once you cut on internal server reporting, that dialog is shown.
2. Re: Alternative to "Post Result" popup with Internal Server
OpenPegasus Jan 17, 2013 10:22 AM (in response to Jim Leichliter)Thanks Jim. Curious: does the widget require that the "Enable reporting for this project" checkbox is checked in the project, and also that the "post results" button is used to send those variables to the server side script?
3. Re: Alternative to "Post Result" popup with Internal Server
Jim Leichliter Jan 17, 2013 10:35 AM (in response to OpenPegasus)No it does not require reporting to be cut on. The "post resutls" is a regular Cp button that's being used by the widget. The only thing to watch for is that all the Cp user variables you're sending over should be defined in the variables panel.
Jim Leichliter
