Recordings within published swf won't play
Jan 11, 2013 Jan 11, 2013
Hi, I'm having an issue in CP6 where recordings within a published swf won't load/play when testing the files on a server. Locally, the recordings play fine.
Here's the perpetual loading animation I get when testing the uploaded files:
The entire published folder is uploaded, so I don't think it has anything to do with missing mp4s(this is the format the recordings seem to be in).
Any help would be appreciate, thanks!
Recording
1.5K
Advisor ,
Jan 14, 2013 Jan 14, 2013
First thing that springs to mind is that your server is not setup to handle mp4 files. You need to make sure that the MIME type is set in the server so it knows what type of file an "mp4" is.
www.cpguru.com - Adobe Captivate Widgets, Tutorials, Tips and Tricks and much more..
Hmm, I see. Is there a way to use/set those recordings in another video format, such as an f4v?
Advisor ,
Well you can convert your MP4 files to FLV or F4V by using the Adobe Media Encoder, which installs along with Adobe Captivate.
However it's not that difficult to configure a MIME type on your server.
For Apache/PHP servers: http://wiki.joyent.com/wiki/display/gen/Configuring+MIME+Types+in+.htaccess
For IIS/ASP servers: http://forums.asp.net/t/1470612.aspx/1
Thank you, but it may not be entirely reasonable for me to request the configuration for just this one instance. If I convert those recordings out, how would Captivate know to pull those files in place of the mp4s?
Advisor ,
Okay in that case you would want to take the MP4 files that you have and "drag and drop" them into Adobe Media Encoder. In the right hand column you can select between a number of different system presets. Find "Flash" and then select one of the F4V / FLV presets that you want to convert it to. (you may have to try a variety of them to find the best compromise between quality and size).
Once the videos are re-encoded you relink them in Captivate. Basically delete the MP4 files you have in the project and insert the newly encoded F4V/FLV files.
Jan 21, 2013 Jan 21, 2013
I too am having the same problem and have tried to correct my issue with the fix above of re-encoding to FLV and delevting the old MP4's, but my issues is still there.  Is there something else i need to do?
Would it have anything to do with the flash version i am publishing to?
Jan 22, 2013 Jan 22, 2013
Hi Sunita, I think what cpguru meant was that you would need to delete the recording slides and simply import the FLVs in, as I've noticed the MP4s don't actually show up in your library for you to relink. Does that make sense?
Jan 24, 2013 Jan 24, 2013
yes thank you, seems to have helped.
Help resources
