Hallo, I have a Samsung Galaxy Tablet N 10. Last week there was a system update. Since that day I cant load my ebooks to the ebook reader because it doesnt accept my login. Can PLEASE anybody help me? I have bought so many ebooks. Thank you.
Moved this to the digital editions forum
Thank you
What software are you using on the Samsung Galaxy Tablet N 10 to read eBooks?
You probably need to reregister you AdobeID with that software:
you may need to unregister and then reregister (in case it half remembered the registration but not completely through the system update).
Probably somewhere in the settings of the app: I can't give any more details.
Thank you. Do you know how to do this?
If you say which eReader app you are using I may be able to find out.
Even when you say which app, I haven't got an android device myself so can't check out for sure.
If you are using Bluefire (one of the most popular Adobe DRM enabled free readers), see
http://www.bluefirereader.com/bfr-user-guide.html Chapter 1: Authorizing Bluefire Reader
Hallo , I use the eBookApp. I have tested other apps, the same, I cant register. Thank you for your helping.
Now I have loaded the bluefirereader and still get the message "Autorization failded. Your Account has not been authorized on this device. Please make sure your divice´s clock is set correcktly. An incorrekt clock my prevent authentification." To load my book I need to load the app dropbox, but if I read the authorization, I really doubt to allow all the things they want.
Do you have another solution? Please. Thank you so much.
Have you run through the authorization process on Bluefire, using the same AdobeID as on the host?
There are some cases where different clocks on PC and device cause Abobe DRM to complain: make sure they are both same time and same timezone.
I'll have a look at eBookApp if I can; I hadn't heard of it before.
Hallo,
yes, I have run through the authorization process on bludfire. Still the same. I also checked the time zone and the time. Thank you for your help.
Sorry; I can't think of anything else to try.
If you do get a solution please post it back here so others can benefit from it too.
