5 Replies Latest reply: Jan 15, 2013 5:16 AM by Steve Grisetti RSS
    PE11 - Organizer hanging
    fredowww66 Community Member
      When I use the organizer delivered with PE11 (dutch version) for importing my clips from cam (usb) to a new album (create) Organizer is hanging after importing the clips.
      With hanging I mean 'freezing'. So I don't get any error message, the program just freezes. After abort the program (with ctrl-alt-del etc), it seems that all the clips are imported.
      pc system is a core I7, systemdisk ssd64 (with os win7 h) and PE11, 8 gig ram, data (f.e. all videofiles) on traditional harddisk. Cam is Panasonic HCX900.
        • 1. Re: PE11 - Organizer hanging
          Steve Grisetti CommunityMVP
          I recommend you use Premiere Elements rather than the Organizer to add media from your camcorder to your computer and project.
          When you add video using Premiere Elemenets' Add Media tools (the Video Importer), the program will automatically download the necessary components to work with that video.
          For best results, shoot only in 1920x1080 AVCHD mode on your camcorder.
          Also make sure you've got the latest version of Quicktime from Apple.
          • 2. Re: PE11 - Organizer hanging
            But i've read that in that case all clips are directly on the timeline and this is what I want to avoid ... ?
            And what is the purpose of Organizer than ?
            • 3. Re: PE11 - Organizer hanging
              If you work in Expert view, your clips will not be added to the timeline automatically.
              Please try my suggestion and see if it makes a difference.
              • 4. Re: PE11 - Organizer hanging
                In that way import is going slow (but that was the same with organizer) but PE is not crashing after import.
                And you can indeed choose (enable or disable) for direct placement of the clips on the timeline.
                Project was small, so for bigger projects I will certainly use this direct import than. It's also a step less because you don't have to drag the clips from Org. to Elements ...
                A pitty that you loose the organizerfunctions but crashing issues is the last that I want :-)
                • 5. Re: PE11 - Organizer hanging
                  If you use Premiere Elements to import the video from the camcorder to your computer, the Organizer should then work with the clips.
