I.ve just imported a RH9 Web Help project into RH10. This upgraded without a hitch and can be viewed in all browsers necessary
However I'd created a custom skin and had modified the following files:
whskin_frmset01.htm
whskin_mbars.htm
whskin_tbars.htm
whstart.js
When I overwrite the generated files with my amended versions, all that is displayed is the top tool bar. No TOC, content or anything, and the search/index is also broken. I'm guessing that these files have been altered somewhat in RH10?
Mark
Somewhat Some files have basically been rewritten. This was required to make WebHelp compatible with local help on Chrome (among other things).
Do you require help amending the RH10 files? If not, use a diff tool (such as the compare utility in Notepad++) to find the changes from the default files in RH9 and make those available in RH10.
Greet,
Willam
Hi Willam,
Thanks for the quick reply. I thought as much. I'll sort it out.
Cheers
Mark
