26 Replies Latest reply: Jan 19, 2013 11:05 AM by JSS1138 RSS
    Blu-Ray
    wayne greensill Community Member
      Hi there,
      I have just completed a wedding project in Premiere CS.6 with a Timline length of  03:01:34:23. Files are MXF Format as it was shot with a Canon XF305.
      I now want to transfer this into Encore would is best to go the Dynamic Link way or just export it out through AME?
      My other question is will I get the 3hour timeline on one blu-ray disc, I only want to use one main menu also?
      I look forward in hearing your comments.
      Regards
      Wayne
        • 1. Re: Blu-Ray
          JSS1138 CommunityMVP
          I just spent about a week trying to get this to work, as getting 3 hours of quality HD onto a single layer BD is not easy using Adobe tools alone.  Here's what I ended up doing.
          1. Install the free UT codec.
          http://umezawa.dyndns.info/archive/utvideo/
          2. Install Xvid4PSP (version 5, not 6)
          http://www.videohelp.com/tools/XviD4PSP
          3. Export out an AVI file using the UT codec, YUV420 option (ULYO).  You don't need audio, just video.  (The file will be huge.  Have plenty of room, like 500GB or more available space.)
          4. Open that exported AVI in Xvid4PSP.
          5. Under Format, select BluRay
          6. Filtering, Color Correction and Audio set to Disabled.
          7. For the Video encoding, select any x264 preset.
          8. Click the gear next to Video encoding, and on the CLI tab, erase what's there and paste the following, then hit Apply and OK.
          --crf 22.0 --preset slower --ipratio 1.00 --pbratio 1.00 --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 24 --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --bluray-compat --open-gop
          9. Hit the Encode button and select your preferred directory.  You may get a warning about other files, just hit OK.
          10. The encoding may take all night.  On my i7 920, it took about 8 hours.
          11. Once encoding is done, you can dig into the Stream folder and take out the video file - 0000.mts or something like that.  Bring that into Encore as an asset, it will not require transcoding.
          Viola, a very high quality, 3 hour HD file that fits onto a 25GB BD with plenty of room to spare for audio and menus.
          • 2. Re: Blu-Ray
            That sounds great Jim thank you. I will give that a go right now.
            Regards
            Wayne
            • 3. Re: Blu-Ray
              HI Jim,
              When you say export out using the YUV420 option do I use the YUV420 (ULY0) or the (ULY2) version? I am in PAL Land, U.K, so will this make any difference?
              Wayne
              • 4. Re: Blu-Ray
                Stan Jones CommunityMVP
                Nice, Jim!
                • 5. Re: Blu-Ray
                  SAFEHARBOR11 Community Member
                  Hi Jim,
                  Thanks for the sharing your alternate workflow, but you didn't state why you couldn't/didn't use Adobe. Did you find the quality lacking? I just fired up a bitrate calculator that suggested 17 as the data rate for 3 hours of H.264 Blu-ray, and I exported a short sample at that rate and thought it looked pretty good. I guess it is up to the individual to compare samples and figure out the workflow that is best for their needs, or "beauty is in the eye of the beholder"
                  Jeff
                  • 6. Re: Blu-Ray
                    ULY2 is 422.  It'll work, but the file will be unnecessarily larger.  The 420 version is best for this purpose.
                    PAL makes no difference here, however it will in the CLI window.  Those settings presumed 24p.  What's your source media?
                    • 7. Re: Blu-Ray
                      I did.  Especially the lower light/high ISO shots.  x264 in CQ mode is just beautiful, and at smaller file sizes.
                      • 8. Re: Blu-Ray
                        Hi Jim,
                        Thanks for again for the reply. My source media is Mxf, shot with the Canon XF305.
                        Wayne
                        • 9. Re: Blu-Ray
                          I had to re-encode again as I forgot to put a audio track in, fool I am!
                          So just waiting again for it to finish encoding 36% at the moment 3hrs to go it says, but I will let you know how the quality looks.
                          Regards
                          Wayne
                          • 10. Re: Blu-Ray
                            Hi Wayne,
                            When exporting a Premiere timeline to DVD or Blu-ray output, the audio is typically encoded to a separate .wav file. Therefore if you have already encoded the program, and later realize you need to change or fix the audio back in Premiere, simply do so, then just export as a .wav file which takes just a couple of minutes, and drop that into the Encore timeline with the video you had encoded earlier. No need to re-do the entire works, unless you had modified the video or length of the program. I do this quite often, as I might notice some audio issue when previewing the Encore project and can quickly correct it.
                            Jeff Pulera
                            Safe Harbor
                            • 11. Re: Blu-Ray
                              Hi Jeff,
                              Thanks for your reply. I wish I had have known that earlier lol. As I have now started encoding again Aghhh!
                              Many thanks
                              Wayne
                              Sent from Samsung mobileSAFEHARBOR11 <forums_noreply@adobe.com> wrote:Re: Blu-Ray
                              created by SAFEHARBOR11 in Encore - View the full discussion
                              Hi Wayne,
                              Jeff Pulera
                              Safe Harbor
                              Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at http://forums.adobe.com/message/4998173#4998173
                              Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4998173#4998173
                              To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4998173#4998173. In the Actions box on the right, click the Stop Email Notifications link.
                              Start a new discussion in Encore by email or at Adobe Community
                              For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
                              • 12. Re: Blu-Ray
                                When you must reexport for Encore, it is best to export to a new name; "replacing asset" with the same name often leads to problems.
                                • 13. Re: Blu-Ray
                                  Thank you Stan I will keep that in mind.
                                  • 14. Re: Blu-Ray
                                    Hi Jim,
                                    I have done exactly what you have said to do, I think? I have now imported the 00000m2ts file into Encore and the frame size is 720x576 and is untranscoded is this correct?
                                    Wayne
                                    • 15. Re: Blu-Ray
                                      Update! I think it was my own fault exported it out as 720x576 rather than changing it to 1920x1080 derrr!
                                      • 16. Re: Blu-Ray
                                        I said this in post 1.
                                        "3. Export out an AVI file using the UT codec, YUV420 option (ULYO).  You don't need audio, just video."
                                        • 17. Re: Blu-Ray
                                          That'll do it.
                                          • 18. Re: Blu-Ray
                                            I mean like 1080i/25?  Or something else?
                                            • 19. Re: Blu-Ray
                                              Hi Jim,
                                              Yes the source is 1080i/25.
                                              I have now re-encoded the avi and imported the 00000m2ts file into Encore and have noticed it needs transcoding again, is this correct?
                                              Wayne
                                              • 20. Re: Blu-Ray
                                                Oh no!!
                                                Now I'm getting an code 25 error not enough disc space, But when I start the build it says there is loads of space left on the disc and I also noticed it was importing the 0000_sessionfiles_Asf_session_1_video.m4v whatever that is??
                                                Wayne
                                                • 21. Re: Blu-Ray
                                                  It is not.  Properly done, the file will not require transcoding.
                                                  The CLI settings listed earlier are for 24p media.  It will probably have to be adjusted for your 25i media.
                                                  • 22. Re: Blu-Ray
                                                    Hi Jim,
                                                    Sorry about this but I'm new to all this with Blu-Ray.
                                                    The media I took with the Canon XF305 was filmed at 1920x1080 50mbps 50i frame rate. Would you know what the CLI settings should be at by any chance?
                                                    Sorry I should have told you this in the first place.
                                                    Regards
                                                    Wayne
                                                    • 23. Re: Blu-Ray
                                                      Wayne,
                                                      Being to new to Blu-ray, you might try the standard workflow before jumping into complex third-party shareware stuff that needs a script to run. Trust me, I have learned the hard way from years of experience. Most recently fighting with the "HD2SD"  avisynth workflow business and multiple third-party softwares involved and endless testing and burning of coaster discs trying to attain the Holy Grail of DVD quality.
                                                      Why not just encode your video using AME? If my math was correct the other day and you encode at 17, either CBR or using 17 AVG for VBR, that should get you going. I know Jim said he wasn't happy with the quality, but everyone has their own set of eyes and expectations, and the source footage plays a BIG part in how the end result comes out as well.
                                                      I see so many people on forums saying they would NEVER put two hours on one DVD, yet that is all I ever do and NO ONE has EVER complained about my quality. EVER. After 20 years in the business, I have found that no one is as fussy about picture quality as ourselves. The average person doesn't know the difference, and might just be THRILLED to have their wedding on Blu-ray and would never notice any compression deficiencies that us "experts" like to nitpick about. I see compression all the time on cable shows and complain to my family, "Did you SEE that?!" and they think I'm crazy.
                                                      I gave my own brother a 3-hour Blu-ray of HIS wedding celebration and it looked great to me and everyone else that watched it (yes, I also supplied the shorter version).
                                                      Do what you gotta do, but it's your time ;-)
                                                      Jeff
                                                      • 24. Re: Blu-Ray
                                                        Jeff's probably right.  Your 25i media will complicate things, and I don't have any to test with.
                                                        • 25. Re: Blu-Ray
                                                          Ok thank you both. I will spread the project over two discs then.
                                                          Many thanks
                                                          Wayne
                                                          • 26. Re: Blu-Ray
                                                            If you want to play around and test things out yourself, this link will help you understand the settings in Xvid4PSP available when you click that little gear icon.
                                                            http://mewiki.project357.com/wiki/X264_Settings
