Hi All,
I am getting a weired session issue. It is showing me session variable is undefined when it should be defined.
Environment details:
Web Server:IIS7
OS:Windows Server 2008 R2 Standard, Service Pack 1 64 bit
Application Server:CF9
Problem Description: It is a page for collection customer review. I have used <cfparam> to declare all session variable that I am going to use
and use StructKeyExists function for checking variable exsistant. The problem is that it is throwing variable undefined error just after checking
for the exsistant of that variable.
Here is the code snippet. :-
<cfparam name="session.productReview" default="#StructNew()#">
<cfparam name="session.productReview.productReviewCustomerCity" default="">
<cfparam name="session.productReview.productReviewCustomerState" default="">
<cfparam name="session.productReview.productReviewCustomerEmail" default="">
<cfparam name="session.productReview.productReviewCustomerFirstName" default="">
<cfparam name="session.productReview.productReviewCustomerLastName" default="">
<cfparam name="session.productReview.productReviewCustomerRating" default="">
<cfparam name="session.productReview.productReviewCustomerReview" default="">
<!---get states (US)--->
<cfset getStates = application.toolsObj.viewStates()>
<!---get the provinces (Canada)--->
<cfset getProvinces = application.toolsObj.viewProvinces()>
<!---get the list of contries--->
<cfset getCountries = application.toolsObj.viewCountries()>
<cfset session.productReviewHumanFlag = 0>
<cfparam name="session.productReviewHumanFlaguuid" default="#CreateUUID()#">
<script>
productReviewUnique = "<cfoutput>#session.productReviewHumanFlaguuid#</cfoutput>";
</script>
<cfoutput>
<form name="theProductreviewForm" id="theProductreviewForm" format="html" action="/components/formProcessing.cfc" onsubmit="return checkForm(this)"
enctype="multipart/form-data" method="post">
<input type="hidden" name="method" value="someMethod"/>
<table width="100%" border="0" cellspacing="0" cellpadding="2">
<tr>
<td valign="top" class="label error-label" nowrap="nowrap">State</td>
<td class="side-padding-10">
<select name="productReviewCustomerState" id="productReviewCustomerState" class="field-75" req="open"
message="State is required">
<option value="" selected="selected"></option>
<cfif isDefined("getStates") AND getStates.recordCount GT 0>
<optgroup label="States">
<cfloop query="getStates">
<cfif StructKeyExists(session, "createAccount")
AND StructKeyExists(session.createAccount, "productReviewCustomerState")
AND session.createAccount.productReviewCustomerState EQ getStates.State>
<cfset page.selectedState = ' selected="selected"'>
<cfelseif StructKeyExists(session, "productReview")
AND StructKeyExists(session.productReview, "productReviewCustomerState")
AND session.productReview.productReviewCustomerState EQ getStates.State >
<cfelse>
<cfset page.selectedState = ''>
</cfif>
<option value="#getStates.State#"#page.selectedState#>#getStates.State#</option>
</cfloop>
</optgroup>
</cfif>
<cfif isDefined("getProvinces") AND getProvinces.recordCount GT 0>
<optgroup label="Provinces">
<cfloop query="getProvinces">
AND session.createAccount.productReviewCustomerState EQ getProvinces.Province>
<cfset selectedProvince = ' selected="selected"'>
<!--- I have got error with this line below --->
AND session.productReview.productReviewCustomerState EQ getProvinces.Province >
<cfelse>
<cfset selectedProvince = ''>
</cfif>
<option value="#getProvinces.Province#"#selectedProvince#>#getProvinces.Province#</option>
</cfloop>
</optgroup>
</cfif>
</select>
</td>
</tr>
<tr>
<td align="right" colspan="2">
<input type="image" name="imageField" id="imageField" src="/assets/images/button-save.png" />
</td>
</tr>
</table>
</form>
</cfoutput>
</cfif>
<cfif StructKeyExists(session, "productReview")>
<!---reset all session variable--->
<cflock scope="session" type="exclusive" timeout="60" throwontimeout="false">
<!---product review structure--->
<cfset session.productReview = StructNew()>
<cfset session.productReview.productReviewCustomerCity = "">
<cfset session.productReview.productReviewCustomerState = "">
<cfset session.productReview.productReviewCustomerEmail = "">
<cfset session.productReview.productReviewCustomerFirstName = "">
<cfset session.productReview.productReviewCustomerLastName = "">
<cfset session.productReview.productReviewCustomerRating = "">
<cfset session.productReview.productReviewCustomerReview = "">
<cfset session.productReview.errorMessage = "">
<cfset session.productReview.formSubmitted = 0>
</cflock>
</cfif>
As you can see that I am using <cfparam> for "session.productReview" but still it showing me variable undefined.
ERROR Details:
coldfusion.runtime.UndefinedElementException: Element PRODUCTREVIEW.PRODUCTREVIEWCUSTOMERSTATE is undefined in SESSION.
EVENTNAME | [empty string] | ||||||||||||
EXCEPTION |
Here is the dump of session variable after the error in application.cfc "Onerror" Method.
productquestion |
productreview |
It's really pissing me off.
What is the set timeout for your session scope in the CF Admin?
I was just informed, yesterday, that our session is set to timeout after 8 hours. We are having intermittent session variable issues. Apparently, something is emptying the session scope without destroying the variables, so when we check with StructKeyExists, the variable exists, but it's either empty, null, or corrupted.
^_^
--My issue is also intermittent . We all have tried to reproduced it many way but unable to solve the mystry.
--In my application we have set it to 1 hour. I will inform you CF Admin setting later.
Do have any guess why it is hapening?
Thanks for your reply and inform me if you need any other information.
Saurav
Unfortunately, we have not yet been able to determine what is causing this session issue.
Best of luck in figuring your situation out. Maybe if you set the timeout to 20 minutes (default for CF), that might fix it. Our higher-ups want it set to 8 hours, so we can't arbitrarily adjust to a lower timeout.
^_^
For a start, delete the stray '</cfif>' located just after the cfoutput closing tag.
Chances are, the session variable is simply undefined. You have yet to give us perhaps the most relevant information, that is, where this piece of code is located.
</cflock>
</cfif>
Most of this is repetition, hence unnecessary. You have already initialized the productReview variables, using cfparam. Therefore, what you require here is simply:
</cfif>
This is initialization code, so the lock is unnecessary.
I have a page showing product information. I am includeing this page(code you are seeing) is in different page. I use <cfinclude> tag to include the cod in page where I am showing product information.
Page1: Pr_detail.cfm
Page2:Pr_review.cfm
So I am include "Pr_review.cfm" in "Pr_detail.cfm" using cfinclude.
"Most of this is repetition, hence unnecessary"
The repetition is for initializing the session variable. It is required because the form data is being stored in "session.productReview" after submitting form. So after each submission I am re-initializing the session variable.
Thanks a lot for replying and excuse me for late reply.
Please inform me if you need more information or simply my reply is not clear.
Happy weekend..:)
