What does this mean?
attach a screenshot of the error message.
It means what it says, I guess.
Which Adobe product? Which operating system?
Adobe Digital Editions.Windows XP..I don't even know what a liscense key is, but
thats what the message box says when I try to open a previously downloaded
e-book that I was actually able to read yesterday.
I tried to download 3 e-books today from my regional library but couldn't read
them either.Got a messa
ge box that says: Unable to download..error getting liscense..Liscense Server
Communication Problem...E_AUTH_
BAD_DEVICE_KEY_OR_PKCS12
the is from bwolfe:
regarding the E_AUTH_BAD_DEVICE_KEY error...
We can't tell you -exactly- what this is, but we can give you some general direction.
On the Mac, Digital Editions 1.5 stores an encryption key (to make sure our client to server calls are secure) in your OS X Keychain.
If there is a problem creating this key then E_AUTH_BAD_DEVICE_KEY is the error you'd see.
The key information is stored as an application password in your keychain. Likely causes of failure include denying access to Digital Editions, or locking your user keychain, and not entering their password when prompted.
If you're denying access explicitly to Digital Editions, well don't do that (ha. )
Now, you may not be doing this intentionally. The access permissions on OS X are complicated, so this could be a side effect of some other permission work. You can explicitly grant Digital Editions access to the the keychain item:
Open Keychain Access (Applications/Utilities)
Select Passwords from Category
Select Digital Editions from password list
Click info button (or press Cmd+i)
(Dialog labeled Digital Editions should appear)
Select Access Control tab
Click + button
Navigate to our install directory and select ADE 1x5
Click Save
Close Dialog
Launch Digital Editions.
Anyway, hopefully this helps you narrow the issue down.
Bentley Wolfe
Senior Support Engineer, Flash/Flash Player/Digital Editions
Adobe
I am using Windows XP.
Moving this discussion to the Adobe Digital Editions forum.
Please try downloading a book from our sample library at http://www.adobe.com/products/digital-editions/eBook.html. If you are able to download the book successfully then please contact the support team responsible for your e-book downloads from your library.
