Show 1 reply
1. Re: How to apply pattern for print purposes?
Kadut Jan 18, 2013 5:48 AM (in response to TomRomaniuk)Not sure what you mean by 'recognize' two parts - but if you want to separate them on two layers, you will first need to Trace the artwork in Illustrator in order to create a vector version of the graphic. After you have Traced it, you need to Expand it, and then select the black areas. That way you can put the black on a different layer than the pattern in the background.
Hope this is what you meant?
