3 Replies Latest reply on Aug 1, 2008 1:08 PM by whertzing
    Extracting Data from Nested XML Elements into Flex
    alice_data Level 1
      I am a newbie and have just started using Flex. I have a little XML that I created from PHP in the following:
      <student>
      <id>001</id>
      <name>Test I</name>
      <instructor_name>
      <first_name>Tara</first_name>
      <last_name>Morrison</last_name>
      </instructor_name>
      </student>
      I used HTTPService provided by Flex to extract the data, and I seem to have no issues extracting the first two columns. However, When I got to the instructor_name, the datagrid gives me this on the screen produced by the HTML: [object] [Object].
      This is what I have in my Flex to extract this particular element:
      <mx:DataGridColumn headerText="Instructor Name" dataField="instructor_name"/>
      Does anyone have any tips on how I can get it to display Tara Morrison in my actual result?
      Anything is appreciated.
      Alice
        • 1. Re: Extracting Data from Nested XML Elements into Flex
          FlexPrashant Level 1
          How do you are taking result of http serivce .. Means to say as Array Collection or xml ... show me your code may be it will help me to solve the problem
          • 2. Re: Extracting Data from Nested XML Elements into Flex
            alice_data Level 1
            I have learned that the simplest way is to use the label function in Flex, like the following:
            private function lfnGeneral(item:Object, column:DataGridColumn):String
            var sLabel:String = ""
            var sHeaderText:String = column.headerText; //so we can handle the variables
            switch (sHeaderText) {
            case "ID":
            sLabel=item.ois_id;
            break;
            case "Name":
            sLabel=item.name;
            break;
            return sLabel;
            Of course, the backdrop is that the name of the item has to be the same as what appears in the rendered XML file from PHP or any other programming language.
            • 3. Re: Extracting Data from Nested XML Elements into Flex
              whertzing Level 1
              Hmm.. I'm a newbie too, but looking at your XML, it seems the <instructor_name> has no direct data, instead it has two child nodes first_name and last_name. Seems you should calling a function that accepts an object, passing it the <Instructor_name> object, and in that function concatenating the children data.
              Check out the help section "Using item renderers with the AdvancedDataGrid control", create and assign a renderer for your <instructor_name> column, and concatenate the two name fields inside of the renderer function.
              Again, I'm a newbie myself, and I have not tried the suggestion above, but I hope it points you toward a solution.
