I have a CF page that needs to use user authentication from an ASP.NET machine, so I'm trying to call a web service to determine whether or not the user has been authenticated.
I'm using this code:
<cfinvoke
webservice="https://my-domain.com/SessionQueryService?wsdl"
method="UserLookupServiceService"
returnvariable="authenticated"
Running this returns the following error:
Unable to read WSDL from URL: https://my-domain.com/SessionQueryService?wsdl.
Error: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated.
I'm assuming this is a certiificate problem, since when I visit the ASP.NET machine via a browser, I get a certificate warning and have to add an exception. Is my assumption correct, and is there a way around it?
OK, so I fixed this authentication problem. Now I'm a little closer to getting it working. I just have to figure out how to get the session ID from the .NET server (which seems odd, because you'd think invoking the web service would create a session ID).
If anyone has any experience with this, any advice would be appreciated.
Now I have the sesssion ID I needed, and it's on to the next point of failure.
Web service operation userLookupBySessionResponse with parameters {applicationName={xxxx},endUserIPAddress={xxxx},accessCode={xxxx},sessionId={xxxx}} cannot be found.
I've Googled and Googled, with no luck. If I browse my web service URL I get an Axis 1.4 XML file with several entries. I'm assuming that the "wsdl:message name=" part is what I use for my <cfinvoke> method, but I could be wrong. I assume that because there are "wsdl:part name="s that match my invokearguments.
It seems like I'm doing everything right, yet still the message above. I have no idea where to go from here.
Woohoo! Got it to work. I was calling the wrong method. Once I inspected the XML file more closely I realized my mistake.
