exclamation: "This is impossible!"
Jan 02, 2007 Jan 02, 2007
We have a large site with lots of traffic.
I have reieved a number of errors in our log files
EX: Application:The request has exceeded the allowable time limit Tag: CFSTOREDPROC
The only problem is, according to this document.
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_19438
The CFSTOREDPROC is an exception to the timeout rule.
Document snippet:
Tag exceptions:
There are certain tags that will not "obey" a timeout, whether it's set in the ColdFusion Administrator or in code on the CFM page. These tags are cfstoredproc,cfcontent, cfftp, cfexecute and cfobject. Also, CFX tags fall into the category of not obeying the ColdFusion
Has anyone else seen this issue?
Advanced techniques
288
Advocate ,
We were having a similar issue and the culprit wound up being our database connection settings on our firewall. Sounds like your error is CF generated, so that may not be a big help, but just to be sure I would double check the settings of the hardware you have between your server and your db (if they are running on separate boxes).
Advisor ,
Jan 03, 2007 Jan 03, 2007
That technote does not mean that you will not see that error in the logs.
It's just warning about cases when you could see a hung thread rather than the timeout you would otherwise expect.
Your logs mean that the CFSTOREDPROC took too long but did eventually return.
Jan 04, 2007 Jan 04, 2007
Your logs mean that the CFSTOREDPROC took to long but did eventually return.
If that is just a warning then CFMX/JRUN should be more explicit about the so called 'exception' to the rule.
Documentation
