I have to do with flash/actionscript where user draw signature and save it jpg-file to database. I had found actionscript code where i can draw the signature. But how i save it? In animation i have save_button. When user push button he can save his signature to jpg-file. I had searched many hours answer from Google and tested many examples and nothing worked..
My actionscript looks now:
var penSprite:Sprite = new Sprite();
var mouseDownFlag:Boolean = false;
penSprite.graphics.lineStyle(1,0x000000);
stage.addChild(penSprite);
stage.addEventListener(MouseEvent.MOUSE_DOWN, mouseDown);
stage.addEventListener(MouseEvent.MOUSE_MOVE, mouseMove);
stage.addEventListener(MouseEvent.MOUSE_UP, mouseUp);
function mouseDown(e:MouseEvent):void
penSprite.graphics.moveTo(e.localX, e.localY);
mouseDownFlag = true;
function mouseMove(e:MouseEvent):void
if (mouseDownFlag) penSprite.graphics.lineTo(e.localX, e.localY);
function mouseUp(e:MouseEvent):void
mouseDownFlag = false;
you can use the jpegencoder class to save your bitmap. google for a tutorial if you need help using it.
If it's a signature I'd recommend PNG, you don't want to lose quality.
This is more of a server-side question than Flash. Flash needs to communicate with a script on a server that will insert the data. Flash typically does not communicate with a database server directly. Common languages like PHP have their own Image processing functioanlity as well as database connectivity. Your job would be to convert the bitmap to binary, send it to your script, have the script encode the data in a format (PNG) and then insert it into a binary-friendly server like a BLOB columns in a database.
Here is your source code updated. You must publish your SWF for 11.3 or newer. Take a look UPDATED CODE section
function mouseDown(e:MouseEvent):void {
function mouseMove(e:MouseEvent):void {
if (mouseDownFlag) {
function mouseUp(e:MouseEvent):void {
UPDATED CODE
var jpeg_bytes : ByteArray;
stage.addEventListener(KeyboardEvent.KEY_DOWN, save);
function save(e:KeyboardEvent):void{
if ( e.keyCode == Keyboard.SPACE ) {
stage.removeEventListener(KeyboardEvent.KEY_DOWN, save);
var jpg_bmp : BitmapData = new BitmapData(stage.stageWidth,stage.stageHeight);
jpg_bmp.draw(penSprite);
var JEO : JPEGEncoderOptions = new JPEGEncoderOptions(88); // 88 it's a quality
jpeg_bytes = jpg_bmp.encode(jpg_bmp.rect,JEO);
var fs : FileReference = new FileReference();
fs.save(jpeg_bytes, "image.jpg");
