I developed a sample component with a single service and 2 operations mapped to 2 methods of implementation class.
Also i tried using composite editors in component.xml and also used property-editor tags.
Component gets installed properly and start properly.
Even when i try to put operations on process map, both operations comes, but as soon as i click on process properties it gets hanged, nothing happens it shows Input and Ouput sections are loading but nothing happens....
My component.xml file looks like as:-
<component xmlns="http://adobe.com/idp/dsc/component/document">
<component-id>com.tcs.sample.customer</component-id>
<version>${project.version}</version> <!--Pick up version from project pom.xml-->
<!--<load-class>com.tcs.impl.CustomerServiceImpl</load-class> -->
<bootstrap-class>com.tcs.BootstrapService</bootstrap-class>
<lifecycle-class>com.tcs.LifecycleService</lifecycle-class>
<descriptor-class>com.adobe.idp.dsc.component.impl.DefaultPOJODescriptorImpl</descriptor-class>
<search-order>PARENT_LAST</search-order>
<!--<class-path></class-path> Include external jar if you've dependencies-->
<supports-export>true</supports-export>
<export-packages>
<package>com.tcs.impl</package>
<package>com.tcs.model</package>
</export-packages>
<data-types>
<data-type java-class="com.tcs.model.Customer" id="com.tcs.model.Customer" standard="true"/>
<data-type java-class="com.tcs.model.GenderTypes" id="com.tcs.model.GenderTypes" standard="true"/>
</data-types>
<editors>
<composite-editor id="CustomerEditorType">
<composite-type>com.tcs.model.Customer</composite-type>
<attributes>
<attribute name="firstName" title="First Name"/>
<attribute name="lastName" title="Last Name"/>
<attribute name="age" title="Age">
<property-editor editor-id="com.adobe.idp.dsc.propertyeditor.system.SpinnerPropertyEditorComponent"/>
</attribute>
<attribute name="dob" title="Date of Birth">
<property-editor editor-id="com.adobe.idp.dsc.propertyeditor.system.CalendarPropertyEditorComponent"/>
</attribute>
</attributes>
</composite-editor>
</editors>
<services>
<service name="customer" title="Customer Service" orchestrateable="true">
<implementation-class>com.tcs.impl.CustomerServiceImpl</implementation-class>
<request-processing-strategy>SINGLE_INSTANCE</request-processing-strategy>
<supported-connectors>REST,SOAP</supported-connectors>
<specifications>
<specification spec-id="com.tcs.CustomerService"/>
</specifications>
<hint>customer service custom component</hint>
<auto-deploy category-id="Customer" service-id="customer" minor-version="0" major-version="1"/>
<config-parameter name="sample" type="java.lang.String" title="Sample config param for customer">
<hint>sample config param</hint>
</config-parameter>
<operation-config>
<operation-name>*</operation-name>
<transaction-type>Container</transaction-type>
<transaction-propagation>Supports</transaction-propagation>
</operation-config>
<operations>
<operation anonymous-access="true" name="createCustomer" method="createCustomer">
<input-parameter name="customer" type="com.tcs.model.Customer" title="customer">
<property-editor editor-id="CustomerEditorType"/>
<supported-expr-types>Variable</supported-expr-types>
</input-parameter>
<input-parameter name="genderTypes" type="com.tcs.model.GenderTypes" title="gender">
<property-editor editor-id="com.adobe.idp.dsc.propertyeditor.system.Enum"/>
</input-parameter>
<output-parameter name="customerId" type="int"/>
</operation>
<operation anonymous-access="true" name="getCustomerName" method="getCustomerName">
<input-parameter name="customerId" type="int" title="customerId">
<supported-expr-types>Literal,XPath,Template,Variable</supported-expr-types>
</input-parameter>
<output-parameter name="name" type="java.lang.String"/>
</operation>
</operations>
</service>
</services>
</component>
And contract of project is as
public interface CustomerService {
public int createCustomer(Customer customer, GenderTypes genderTypes);
public String getCustomerName(int customerId);
And model class is Customer with proper getters and setters for firstName,lastName,age,gender,dob
GenderTypes is a ENUM with Male, Female as values.
Please help me.
Prashast
Total Likes
I hope you have created a basic (simple) DSC component.
In the xml you have mentioned about two more class definitions "bootstrap-class" and "lifecycle-class".
have you created those classes?
If not, just remove those entries from the xml and deploy the component again. For a basic DSC you need not write any bootstrap/lifecycle implementations.
Nith
Total Likes
