How can I install FMS on Ubuntu 12.04 LTS Server 64bit ?? I follow the install guide, but it dont work.I get this error
"A reqzured package, libcap, was not found on your linux_86_64 Debian." But Licap is alread installed..please help
The latest libcap libraries on Ubuntu 12.04 cause problems with fmsedge process and fmsedge process crashes. For installing Flash Media Server on ubuntu 12.04, install the libcap2-2.17 from http://archive.ubuntu.com/ubuntu/pool/main/libc/libcap2/libcap2_2.17-2ubuntu1.1_amd64.deb
Download the file using wget and install the deb using sudo dpkg –i libcap2_2.17-2ubuntu1.1_amd64.deb
Then install FMS.
Hi, I try it, but i get this error:
my serverinfo:
Prozessor: Intel Sandy Bridge G530
CPU-Leistung: 2 x 2,4 GHz
Arbeitsspeicher: 4 GB
Sorry, that was for AMD processor. Try installing libcap from http://archive.ubuntu.com/ubuntu/pool/main/libc/libcap2/libcap2_2.17-2ubuntu1_i386.deb which is for Intel processors.
Download the file using wget and install the deb using sudo dpkg –i libcap2_2.17-2ubuntu1_i386.deb
i just installed a fresh ubuntu.. i get this error.. i try to install libcap2_2.17-2ubuntu1_i386.deb
but i get an other error this one
I tried installing AMS on fresh installation of Ubuntu 12.04. For AMS to install and work on ubuntu, I had to do following things:
Then try installing AMS. It should work fine.
I cant remove it, because ntp is using libcap.. and now?
Stop ntp using command sudo /etc/init.d/ntp stop and then try above steps.
Chandan_Abhishekis correct. Only thing the wrong libnspr link. here is the correct link. http://security.ubuntu.com/ubuntu/pool/main/n/nspr/libnspr4_4.8.9-1ubuntu2_amd64.deb
Mine is working now
I went into terminal . went to the installAMS maybe installFMS for you and I edited in NANO and look for the line " exit_no_libcap(){ " I changed it to " exit_no_libcap-dev (){" and I did the same thing to the "exit_wrong_libcap " I only added "-dev" to both sections. Install started right up
