Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Connection to external xml file
Avatar
Level 1
How do I use an external xml file as a data source for my LiveCycle form?
I have an xml file on my server that is updated every few days by a script. My LiveCycle form is on the server and can be pushed to the client by the click of a button on a web page or similar. Is it possible to have the LiveCycle form refresh its data before being sent to the client, or every few days?
I was thinking that on the load of the form, a JavaScript function could check if the form is on the server, or check if the xml file is there, and if it is, update itself, else do nothing.
I would rather keep the xml file and the form seperate as other applications and scripts make use of the xml file.
Thanks.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
1) If the form is being used internally on the same network (ie: the xml file is always availabe via network to th form), the form can query local files, but this requires advanced scripting.
I haven't done it with shared network drives tho. - if you do, I use solution two
2)  Assuming you use LC Reader Extensions and the form is 'all over', not always on the originating network.
- Expose the XML file via a webservice (if it is not sensitive data)
- Get the form to query the webservice
3)But if you have LiveCycle installed with Forms.
Use the readXML component and then bind the XML with the Form.
1 Reply
Avatar
Correct answer by
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
