Show 2 replies
1. Re: Pantone Gradient Going Wonky
rob day Jan 24, 2013 12:13 PM (in response to peterpica)Reflex Blue is pretty far out of the CMYK gamut, so the best you can do is spec a CMYK mix and cut down on magenta while keeping cyan at 100%.
Also cyan isn't in the RGB gamut so the display of bright blues with 100% cyan in the mix can be muted relative to the way they will print. If you can get a CMYK process guide, it would be better than using the Pantone solids swatch book.
2. Re: Pantone Gradient Going Wonky
peterpica Jan 24, 2013 1:06 PM (in response to rob day)THANKS ROB!
CMYK process guide is out of the budget, though... will experiment w/your other suggestions.
Regards.
