1. Re: Reorganize existing photos by date
Curt Y Jan 24, 2013 12:38 PM (in response to Sekhar Ravinutala)On the right side of the toolbar there is sort by xxxx. Pick your poision.
2. Re: Reorganize existing photos by date
Sekhar Ravinutala Jan 24, 2013 12:46 PM (in response to Curt Y)No, that just sorts. What I need is reorganize. E.g., say there are two directories: a, b. a has a1, a2 taken on 1/1/13 and a3 taken on 1/2/13. b has b1, b2 taken on 1/2/13. After reorganizing, the files should go to two directories: 2013-01-01 with files a1, a2 and 2013-01-02 with a3, b1, b2. Basically organize by date taken, just the way Bridge would if it were importing from camera (as if a1, a2, a3, b1, b2 were all on the camera in this case).
3. Re: Reorganize existing photos by date
Omke Oudeman Jan 24, 2013 1:24 PM (in response to Sekhar Ravinutala)No, that just sorts. What I need is reorganize.
After having them sorted on date taken you can reorganize them your self, either study a bit about using collections and smart collections and from that place the found files in a folder using drag and drop to the new folder or create those folders and from the sorted result drag and drop them in the wanted folders.
If you use the folder panel to have the folders to drag on in view and also the filter panel with the 'date created' you have also that option to manual reorganize in an easy way
And if you select the main folder and from menu view use show items from subfolder you have to let Bridge cache a bit and then you can also use the filter panel to select date created.
Or you can use a script but you have to create a script are hoping that someone will create this for you
plenty of options
4. Re: Reorganize existing photos by date
Sekhar Ravinutala Jan 24, 2013 1:37 PM (in response to Omke Oudeman)Yes, seeing all the files and sorting by date is not a problem. The issue is to then easily group the files into respective directories as I mentioned earlier. Doing it manually on date/date basis is unfortunately not an option since I have thousands of images from many different dates.
I guess I'll go ahead and use Picasa: with that all I need to do is to specify the directory to import from and it will do the rest...I just thought Bridge would have that option too since it can already do that when importing from camera. I'll watch this thread and log a feature request if it turns out Bridge doesn't have that capability - I think it'd be useful for reorganizing.
5. Re: Reorganize existing photos by date
Omke Oudeman Jan 24, 2013 2:45 PM (in response to Sekhar Ravinutala)I'll watch this thread and log a feature request if it turns out Bridge doesn't have that capability
I agree that it would be useful to have the possibility to also import from HD but meanwhile you do have plenty of options to reach what you need. You only need to read a bit about Bridge, use the view items from subfolder to have all the files in the content window (depending on size and amount this takes time and eats resources and RAM) but before you start experimenting you should make a proper back up of the existing files.
Another option to sort on date would be batch renaming:
Select all the files in the content window and choose menu tools/ batch rename. Inhere select the option to choose for the first field: date and time / date created / yyyymmdd and the next field current file name and check the result for first file at the bottom of the rename window under preview.
You should end up with the creation date in front of the current filename and while using yyyymmdd you have a natural sort order for the files.
If you are happy hit OK and wait a while for the renaming to be saved to the files. Now hit sort by filename.
Personally I have my image files stored in folder per year and month, the day in front does the rest for natural sort order.
