I have Win 7 and IE9 ..m trying to install flash player but its not working..everytime i try opening my game it asks me to download Flash..reinstalling it also didn't work for me...my shockwave flash object is enabled and i have disabled the activex filtering.
Does Flash Player load when you visit this page? If so, what version is reported installed?
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
No, I see the blank box..
Could you try installing our latest Flash Player 11.6 labs release and let me know if that makes a difference? My initial guess would have been that your ActiveX object wasn't enabled or filtering was turned on, but you've checked that. What version was displayed in IE's manage add-ons dialog when you inspected Shockwave Flash Player?
Chris
Thanks Chris. The Shockwave Flash Object version is 11.5.502.146. I uninstalled it and tried installing 11.6 beta from the adobe labs but the installation failed giving the error msg ActiveX flash object could not be registered.
-Meeta
I have the admin account, so there should not be any write permission issue. Below is the log file i copied from system32\macromed\flash
=O====== M/11.6.602.146 2013-01-22+03-26-51.057 ========
0000 00000010 "C:\Users\MEETA\AppData\Local\Temp\{072FDA98-69F3-4C64-AE14-95082A3E694E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_146.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_146_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_146_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010
0011 00000018
0012
=X====== M/11.6.602.146 2013-01-22+03-26-52.726 ========
Very strange thing I noticed is that all my games work perfect in Safe Mode.
I'm looking into the install error. My hunch is that there's a permission issue that's blocking the ActiveX control from being registered. While we wait for the install team to get back to me, please try running the script outlined in the FAQ below that attempts to correct registry, file and folder permissions.
How do I fix Windows permission problems with Flash Player?
As for safe mode fixing the games, this leads me to believe that there's some other utility/service that is being loaded on normal startup that is blocking Flash from working. This is usually caused by security/virus/ad blocking software. Try disabling these to see if that makes a difference.
Chris
The batch file didn't help. I have reinstalled 11.5.502.146 object 40 times but nothing seems to work..I have also uninstalled IE9, now I have IE8 but still every time I try opening my game it asks me to install flash...its been two days and things are not working out
Meeta
I talked with our installer team and they told me that the error you received was due to inadequate registry access when trying to register the active x control. Can you try the following:
1. In your start menu, type cmd
2. Right click the command prompt icon that is found and select "run as administrator"
3. Type "cd:\C:\Windows\system32\Macromed\Flash\" and hit enter
4. Type "regsvr32 Flash64_11_6_602_146.ocx"
What does the dialog that appears say?
Chris
Thanks for ur help Chris ...
The msgbox had this msg "The module "flash64_11_6_602_146.ocx" was loaded but the call to dllregisterserver failed with error code 0x80070005"
Can we do a desktop sharing session Chris, I will uninstall this version and install 11.5.502.146 and u can check why it does not work in normal mode. What is that process/service which is not there in Safe mode and runs in normal mode, which prevents flash to work.
There is another information, not sure if it is of any help or not ..I have downgraded to IE8 and when I load the adobe flash player webpage (http://get.adobe.com/flashplayer/?promoid=JZEFT), it shows a warning msg (Yellow triangle) in the bottom left corner which says
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB7.4; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.3)
Timestamp: Fri, 25 Jan 2013 07:26:19 UTC
Message: Library not registered.
Line: 182
Char: 4
Code: 0
URI: http://wwwimages.adobe.com/www.adobe.com/ubi/template/identity/lib/swfobject.js
Meeta
I'd be happy to help, though I can't make any promisses that I'll be able to solve this issue. This is definitely not normal behavior.
Please send email to ccampbel@adobe.com and we can schedule something for next week.
Chris
