1. Re: export all paragraph style attributes to text file
P Spier Dec 21, 2012 1:08 PM (in response to wbset09)http://pdsassoc.com/downloads/TSRCS2.zip, description at http://pdsassoc.com/index.php?Nav=downssub&Ban=InformalUtilitiesForDownload&Info=downloads /index.php
This is an old script and may need to be placed into a subfolder named "Version 5.0 Scripts" (without the quotes if it doesn't run properly in your curent version of ID.
2. Re: export all paragraph style attributes to text file
wbset09 Jan 3, 2013 6:33 AM (in response to P Spier)Great, I've downloaded the script and placed it in the folder. Now, are there instructions on how to run it? i don't see it in my scritps panel in Indesign...
3. Re: export all paragraph style attributes to text file
P Spier Jan 3, 2013 7:00 AM (in response to wbset09)If you don't see it inthe panel, it's not properly installed.
Where, exactly, did you put it?
4. Re: export all paragraph style attributes to text file
wbset09 Jan 3, 2013 7:06 AM (in response to P Spier) -
5. Re: export all paragraph style attributes to text file
P Spier Jan 3, 2013 7:16 AM (in response to wbset09)Wrong folder.
Move the Version 5.0 Scripts folder into C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Scripts\Scripts Panel\
6. Re: export all paragraph style attributes to text file
wbset09 Jan 3, 2013 7:33 AM (in response to P Spier)Wow. thank you! This is so helpful!
7. Re: export all paragraph style attributes to text file
Digital-junkie Jan 25, 2013 12:57 PM (in response to P Spier)Is there a possibility to run the script on OSX (10.7.5) with InDesign CS6?
I put it in the scripts folder (Adobe InDesign CS6/Scripts/Scripts panel) but there was an error
"Can't locate snippet file. Report can't be generated"
8. Re: export all paragraph style attributes to text file
Michael Witherell Jan 25, 2013 1:02 PM (in response to Digital-junkie)Did you make that subfolder named "Version 5.0 Scripts" and put the script down within that folder?
9. Re: export all paragraph style attributes to text file
Digital-junkie Jan 25, 2013 1:17 PM (in response to Michael Witherell)I put the script now in Adobe InDesign CS6/Scripts/Scripts panel/Version 5.0 Scripts but it didn't work
Meanwhile I found that http://forums.adobe.com/message/5022250#5022250
with a link to that script http://kasyan.ho.com.ua/list_paragraph_and_character_styles.html
it exports less details, but it has all I need
