Importing Excel into Oracle
Jan 03, 2007 Jan 03, 2007
Scenario:
7 users have access to an Excel Sheet.
Any user can use the coldfusion front-end and upload this excel file into an Oracle database.
Excel sheet has 30 columns, but when they click on Upload...only 5 0r 6 columns will be filled.
The rest will be null values in the database.
I'm not in a position to make use of Oracle External Tables neither can I run DB scripts to check for newer Excel Uploads.
As of now I need suggestions on the possible approaches.
Also when user clicks upload:
If col-1 has value then col-2, col-3 should have values and col-4, col-5 should not have any values.
There will be checks like these in place too.
Please suggest how do I check an .xls file if all these conditions are filled per row (assuming that there would be 40 rows per upload per user per day). Do I check the .xls file or do I check for these validations somewhere else, if yese where and how ??
Advanced techniques
248
somewhere else, if yes where and how ??
Either on these forums of the House of Fusion forums, I recently read a
thread about using excel as a datasource. That may offer you some options.
The file could be uploaded to a given location. That location is
configured as a datasource. Use standard SQL operations against it.
Will try what has been suggested. Is there anything more conventional though?
Jan 04, 2007 Jan 04, 2007
Why couldn't you upload the Excel and then use cfhttp to take it and turn it
into a query which you can loop into a database? I do that with CSV files
all the time. Wouldn't that work for Excel?
Documentation
