I was surprised to find that you cannot control the page title of a web app item.
For example:
The page title is just "Brazil" and there's no way to control it? Ideally we'd want something like this for SEO reason.
Business Name - Destinations - Brazil
You could place the SEO Title in the field "Item Name" and then if you would like a different title for the entry, you can create a custom field.
Carol - BCGurus.com - http://bcgurus.com/Business-Catalyst-Templates for only $7
Thank you Carol, simple fix like it 🙂
sf d-)=
But make sure you edit the url. By default the url will use that name as well and that wont be good.
Will do Liam. Most of my url's have already be set but will keep this in mind when creating new web app items.
For your meta, if you not done already just make a custom field for description and meta in the large layout. The system will put it in the head.
Okay excellent, wasn't sure if that was going to work. Had already tried it with the <title> tag to no avail which is why I ended up search of a solution.
sf d-)=
