1. Re: Change color in an Encore motion menu background
Bill Hunt Jan 27, 2013 5:50 PM (in response to BJBBJB1)You are on the right track. A Motion Menu uses a Video Asset (and maybe an Audio Asset too), for the motion.
All you have to do is create a Video Asset, or modify an existing one, Import that into Encore as an Asset, and then use the Pickwhip to link to that for the Motion Menu Background.
Once, those Video Assets for Motion Menus were WMV files, but in those days, Encore was ported for the PC only. Now, with X-platform capabilities, the format is M2v.
I would take the Motion Menu Background Video into PrPro, adjust the colors, and change it, in any way you need, then Export that for Import into Encore. If you have used a Menu Template, then there will be an existing Motion Menu Background Video already associated with it. Just use the Pickwhip to change that association.
Good luck,
Hunt
2. Re: Change color in an Encore motion menu background
BJBBJB1 Jan 27, 2013 8:33 PM (in response to Bill Hunt)Bill,
Thanks a lot! That helps confirm what I need to do.
BJBBJB1
