Hello everyone,
I’m developing on a MAC mini with Flash Builder 4.7 and AIR 3.4. I am working on an ANE and I like to debug it with the XCode simulator. To do that, I am using this template:
I tried to change the <extensions.xml> to refer to "iPhone-x86" and creating the ANE by using ADT command like
"$AIR_SDK_PATH"/bin/adt -package -target ane "$TARGET_NAME" extension.xml -swc "$EXTENSION_SWC_FILE_NAME" -platform default library.swf -platform iPhone-x86 -platformoptions platformoptions.xml "$NATIVE_EXTENSION_STATIC_LIB_NAME" library.swf
Then in Flash Builder (with Debugger) I am trying to debug my application with the XCode Simulator with this command:
adt.jar -package -target ipa-debug-interpreter-simulator -connect 192.168.1.54 -hideAneLibSymbols no -storetype pkcs12 -keystore ios_development.p12 Test1.ipa Test1-app.xml DebugHostInfo.xml Test1.css Test1.swf -extdir /Users/admin/Documents/Adobe Flash Builder 4.7/.metadata/.plugins/com.adobe.flexbuilder.project.ui/ANEFiles/Test1/com.adobe.flexide.multiplatform.ios.platform -platformsdk /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator6.0.sdk
I always get Error:
Error occurred while packaging the application:
ld: warning: could not create compact unwind for __Unwind_Resume: non-standard register 0 being saved in prolog
ld: warning: could not create compact unwind for __Unwind_ForcedUnwind: non-standard register 0 being saved in prolog
ld: warning: could not create compact unwind for __Unwind_RaiseException: non-standard register 0 being saved in prolog
ld: warning: could not create compact unwind for __Unwind_Resume_or_Rethrow: non-standard register 0 being saved in prolog
My questions are:
1. Is my ANE creation process above correct? Or do I have to use "iPhone-ARM" in the ADT Command for parameter "-platform"?
2. Do I need to add i386 architecture to my build settings in XCode under "Valid Architectures" in order to debug it on my MAC mini with Xcode simulator?
3. Is the Flash Builder debugging ADT command correct?
4. And what about this linker problem described here: forums.adobe.com/message/4319610#4319610
thx
marco
Really no one?
The above menntioned commands are correct, both for ane packaging and Flash Builder Debugging.
I tried to package and ane and debug with Flash Builder 4.7 with xcode simulator and it worked fine.
In order to create the Native extension static library, please build your xcode project for iPhone Simulator or iPad Simulator. You can ignore warnings if any.
This should work for you.
Please let me know if you still face issues.
Krati
Hello,
thanksk so far. I can now create an ANE, hopefully it is correct...
Now, while trying to use it in my mobile application, calling the Constructor of my SWC interface > call initNativeExtension() I get an:
Type Error #1009 cannot access a property or method of a null object reference
It seems that my code cannot load the ANE because I cannot instatiate the extension object.
Can you help me ?
THX
marco
